General Indicator / Wiper stalk help
Norwich, Norfolk
Hello all, after a little help.
I've a 2004 Panda and need to replace the indicator and wipper stalk assay which has the steering clock spring built into it due to the horn not working. I don't really want to get this part new from Fiat as it will probably cost a bomb.
My reason for posting in this section is because iirc they're the same as in the late Punto's (2000-2005) (pre Grande). Could someone with a punto of that age post a pic of their stalks. Strange question I know, but I'm hoping it will confirm that they are the same, or similar, meaning I can get one out of a Punto in a scrappy because there are loads of Punto's in my local scrap yards, but no Panda's.
Noy sure if anyone has any pic's of this part in Punto's of this age with steering wheels removed. If so, they will also help.
Many thanks in advanced.
Jon
just by looking at plenty of panda pics they seem to be the same although some appear to have an extra button on the end of the right hand one??? and i cannot fatham what it's for???? as the punto does not have one??? but otherwise cannot see why not..
edit: should be fine looked at another pic with no button...
Hi mate,
You would need 2003-2005 (ie Punto mk2b), not 2000 on. As Ninja says, the 2000 on ones don't have the button on the end of the indicator stalk for resetting the trip etc.
Cant check 100% right now, hopefully someone else can confirm the fittment for you tonight. If not ill check tommrow
Hope that helps,
Alan
Many thanks for the replys so far. My Panda is only a base model 'Active' so dosen't have the button at the end of the stalk. I think that one with a button will fully function the same as the current one except the button on the end just won't do anything.
So we think that I'm looking for a mk2b then. That's the one with the big chunky headlights, and not the rectangular 'projection' headlamps isn't it?
Jon.
Hi guys. Thanks for your help last night. Just to let you know that I went to the scrappy today and found that the mk2 Punto's had identicle looking stalks to my Panda. But when removed the unit as a whole is different only have 6pin plugs and not 9 like the Panda, so unfortunatly they were no good, and I've got to try searching the net for what I need. Thanks again though.
Jon.
Jon.
:yeahthat: tis a shame. Only got to check a few mins ago.
From fiat your looking at around £70 new.
Alan
