Thread Tools
Old 08-02-2009   #1
Fiat Punto 2001 8 valve 1.2 firing order
Having just fitted a new ECU and coils I need to be sure which HT Leads go to which coils t
erminals, I have read the listings and find conflicting results for cylinders 1 and 4. Help please.or does it make any didifference?as long as 1 and 4 go to rear coil and 2 and three goto front coil,thanks.
nurseryfarmer is offline Reply With Quote Quote
Old 08-02-2009   #2
popping out
dan-the-man has donated!
Re: Fiat Punto 2001 8 valve 1.2 firing order
It does need to be right otherwise it wont run properly.
look here http://www.fiatforum.com/punto/10591...nto-1-2-a.html
dan-the-man is offline Reply With Quote Quote
Old 08-02-2009   #3
It's cast into the cylinder head. Look across from the passenger side of the car- you'll see 2314 just above the coils.
Incidently, why have you replaced both the coils and the ECU?
D4nny8oy is offline Reply With Quote Quote
Thread Tools
(G) MK2 2001 Punto Go Mis-firing problems new_horizon Punto (Mk2/2b) 1 09-10-2008 17:13
(T) Punto 60 1242spi Firing Order SlinkyCinqi Punto (Mk2/2b) 4 09-08-2007 20:12
(G) fiat brava 1.4 firing order paganwolf Bravo / Brava 4 22-11-2006 20:53
(G) firing order hensteeth Panda (Classic) 2 06-05-2006 17:55
(T) FIRING ORDER alpunto Punto (Mk2/2b) 1 07-05-2004 23:12
