Hi, I have a Punto 1.2 16v Sporting that I am having problems with. At certain times when I accelerate, the car suddenly holds back as if you had hit a rev limiter, & the car has no power. I have noticed it does it more often when I go to overtake or set off from a junction, if I drive the car accelerating slowly it is less frequent. When this happens & then you have to stop at a junction, when you set off the car appears to misfire & has poor acceleration. The car can sometimes go for days with out it happening or sometimes it will happen every journey.
When I carry out a diagnostic check the code P0220 Throttle/pedal position sensor/switch B circuit malfunction is stored, if I clear the fault then it happens again this same code appears. I have managed to get the fault to appear by flicking the accelerator pedal, I have tried removing the plugs & re fitting & wriggling the connections on the accelerator potentiometer & the throttle body but the fault does not appear, I am reluctant to buy a throttle pedal potentiometer to find this is not the fault, knowing wiring connection problems are an issue, has anyone any ideas or experienced this fault before?
