I have just replaced the steering column stalk switches on my Mk2 Punto as the indicators and lights were not switching properly at low temperatures. This seems to be a common problem. It's a pain to do as both stalks are incorporated in one unit, so the steering wheel has to come off.
I disconnected the battery before starting the job and waited 10 mins before disconnecting the driver's airbag, as per manual. However as the new switch unit was secondhand I thought I'd test it in situ before I put the steering wheel back on. ! MISTAKE ! As the airbag was not connected the airbag ECU records a fault and subsequently my airbag light has been on for a few days.
From searching previous threads it appears that the Punto will not extinguish the light. Stilos, for example, will reset the light if the fault does not re-occur, but it seems that I'm stuck with the light on.
I will have to get the ECU reset at some point, and certainly before my next MOT or accident !! Does anybody know how to reset the ECU without any special equipment?
