Thread Tools
Old 05-11-2008   #1
brake load sensing valve
I am helping a friend to repair the rather rusty braking system on his 95' punto 1.2-75 hp. I've got some problems with faulty brake load sensing valves. All the mechanical parts that "connect the valve" to the moving rear axel is "gone" - taken by the rust. Can someone help? I need to know how it should be. An exploded view, pictures or similar would help a lot. I am located in Norway. Not too much help to get here from the local Fiat dealer. Fiat is not very common over here....
steinar is offline Reply With Quote Quote
Old 06-11-2008   #2
Re: brake load sensing valve
Usually when things like these seize, all they need is a few good whacks with a hammer, some releasing fluid (WD40 etc) and a bit of patience to get everything moving again.
I don't mind being wrong, but I hate it when somebody else is right.
rpaterson is offline Reply With Quote Quote
Thread Tools
(T) Punto mark1, 1.7TD van suspension and brake up grade for heavy load fred1 Punto (Mk2/2b) 3 14-09-2008 14:16
(G) Recall: Brake servo EGR Valve Lou Ulysse 4 11-07-2007 19:56
Brake bias valve Fast Finger Lets Talk FIAT 0 03-08-2005 18:30
(T) Brake proportioning valve hot_fiat Tempra 2 28-06-2005 18:32
(T) Replacing Brake pressure regulating valve Nick_K81 Uno 9 19-05-2005 15:58
