Firstly thanks to littlepip17 and yazza54 for your comments regarding the head problem i had with the broken bolts etc..
I took your advice and had the head skimmed and reconned, bolts came out easily, have now refitted everything, got good compression (12 bar). Engine started but revs where high on tickover (2000), reset ecu and this cured revs.
problem now is. theres smoke coming from the exhaust, looks white but stinks of fuel, fitted new lambda sensor, cat, plugs, oil and filter, air filter, head gasket and skimmed head.
Do you think it could be another sensor? or the ECU or throttle housing, revs are now at 1100, if had a carb, you'd think the choke was stuck on. any ideas, what i could do next? thanks Frank:bang:
