Is it shaped like an engine by any chance? In which case its your engines on board diagnostics system telling you that there is a problem. As its is happening when revving, i would guess at a slight misfire being detected, but if you want to be 100% then have your car plugged in to a diagnostics machine and it will soon tell you what the problem is.
Hope that helps,
Alan
