Thread Tools
Old 30-06-2008   #1
Help in changing transmission oil
Hello,
I own a 2001 Fiat Punto ELX, 16V, AUTOMATIC.
I would like to change the transmission fluid and was wondering if someone could give me a hand with some info.
1. What oil should I use ? Tutela CVT or any other brand works? (examples?)
2. Where is the fill plug (is it the yellow one under the hood?)
3. How can the tranny FILTER be changed and where is it ? Can it be done by me after draining the oil or should be a professional ?
Thank you kindly,
Luc
lukebrenner is offline Reply With Quote Quote
Old 30-06-2008   #2
Bravo 1.8 HLX FTW
The Sultan's Avatar
The Sultan has donated!
Re: Help in changing transmission oil
you must use tutela CVT2 OIL NOT CVT as cvt will bugger the box in a matter of miles cvt is intended for the older type mk1 automatics
the filter is just like an engine filter and is on top of the box it's black in colour
you are best to get your filter and oil from a fiat dealer they will stock both and will supply you the proper fiat tutela cvt2 oil
you need to fill it thou the dip stick tube
i can't guarantee it but think they hold about 2 litres so i would go from there
i assume you are aware the oil must be checked wile the engine is running as it must fill the torque converter and remain at top the dip stick is simply marked with cold and hot as you are changing it it will be cold when you check it so up to the bottom mark wile running
500 door handles fit bravo well chuffed
The Sultan is offline Reply With Quote Quote
Old 30-06-2008   #3
Trader Rating: 10
dave has donated!
3.6ltrs
“What is right is not always popular and what is popular is not always right.”
Albert Einstein.
Old 30-06-2008   #4
Hi there, thanks for the replies
HOLLY SMOKES ! 3.6 liters is the capacity of my automatic tranny ? Geez, I thought it's less than 2 liters.
Briefly, I live in Romania and went today to a company called Cefin (Italian) and bought 3 liters motor oil Selenia performer 5W-30.
So what I'll do, I'll go tomorrow and ask for transmission oil.
Littlepip, I went on the website and there's a product there called Tutela CVT NG (NG stands for "new generation"). Is that the one you're talking about ?
Here's the link :
http://www.flromania.com/oleje/auto_p_tutelacvtng.htm
And yes, I knew that the transmission fluid is to be checked with the engine running.
And still ... is the fill plug the one that is yellow in color ?
Thanks very much.
Luc
Old 30-06-2008   #5
Trader Rating: 10
dave has donated!
the fill hole is the dip stick (level stick?) hole. CVT NG is the one
Albert Einstein.
Old 30-06-2008   #6
Hey Dave, are you really 100% sure it's 3.6 liters ?
I'll be damned if I understand There's 2 dip sticks under the hood : facing the engine, there's one RED on the left side of the engine which is the dip stick for the motor oil. Then there's another one on the right almost at the bottom which is YELLOW. That's the one we're talking about right ?
Thanks,
Luc
Old 30-06-2008   #7
Trader Rating: 10
dave has donated!
yeah thats the one.
yeah its 3.6 T a tech here checked it for me as haynes manual had the wrong amount written in it
Albert Einstein.
Old 30-06-2008   #8
Forum Moderator
T14086's Avatar
T14086 has donated!
dont blame me if its wrong
what engine?
Old 30-06-2008   #9
Trader Rating: 10
dave has donated!
Quote Originally Posted by T14086 View Post
what engine?
double check. thinking maybe 2.6 now its not for engine it for cvt
but i seem to remember having to buy 4 bottles
Albert Einstein.
Old 30-06-2008   #10
K, thanks for your reply Dave. Geez, that will cut deep into my budget as I expect it to be more expensive than a liter of synthetic Selenia motor oil.
Btw, that yellow dip stick is somehow clipped there, you can't just take it out like the one for the motor oil. I'll deal with it.
Thanks guys.
Old 30-06-2008   #11
It's a 1.2, 16 V, motor code 188A5000
Old 30-06-2008   #12
Forum Moderator
T14086's Avatar
T14086 has donated!
gearbox/diff capacity 1.65 litres or 3.6 with automatic transmission...thats what it says.
Old 30-06-2008   #13
Forum Moderator
T14086's Avatar
T14086 has donated!
stick in 2L then check & top up if required to 3.6
Old 30-06-2008   #14
OK, mistery solved. I remembered I had a book that came with the car ... and I checked it and the capacity is 1.98 liters.
Thanks guys !
Old 30-06-2008   #15
Trader Rating: 10
dave has donated!
its not 1.98 liters, trust me ive done mine twice,
Albert Einstein.
Thread Tools
(G) Help in changing transmission oil lukebrenner Stilo 0 30-06-2008 17:57
(G) transmission oil - how much? Luke M Cinquecento / Seicento 19 14-03-2007 12:30
(T) Transmission oil seal KeithT Punto (Mk1) 9 29-12-2006 15:49
(T) transmission oil luka78 Bravo / Brava 3 27-11-2006 15:01
(T) Topping up transmission oil x1/9 4 sale Cinquecento / Seicento 17 12-01-2005 01:32
