have to meaure the valve clearance soon on a 53 plate 1.2 8v engine, do they usuually go out of spec much? are they just a shim and bucket and do you need to remove the cam to get them out?
sam
sam
thanks again for this reply. i know what you mean about the gasket leaking, mine is leaking at the end of the cam over the coil pack. i should be able to get fiat tools, im a tech at a ford dealer ship, our other dealer in cambridge also does fiat so they could send it over. know tons about fords but never done anything to my punto
have the auto data program at work and it says the specs, just not how to do it
sam
the old 1.3 hcs engine, nick names the rattler, my partner has a hcs in ther ka, its such a simple engine to work on, and its pretty much bullet proof, you can run them with hardly any oil in them and they still go
sam
well yea doing em cold is a good ideawell went to do my valve clearances this morning, drove to work, around 2 miles, serviced my car for an hour etc, took the rocker cover off and the engine and cam was still hot, not roasting hot but hurt you hand if you left it on the cam for about 10 seconds, im going to have to do it at home in the morning before its started. another thing for my list of bad things, others being my spark plugs were wrong and that i got a pollen filter when my car does not even have one. engine is abit quiter with new oil though lol
sam
