Hi Guys,
Really need your help with diagnostics on this one. I'll try to keep it as brief as possible.
I have a fiat punto GT 1998. About two years ago my key code light kept coming on and the car wouldnt start as a result. This was resolved when I disconnected the battery. After a few months the code light then remained on and I couldnt start the car and couldnt use it for months. I tried to get the ECU uncoded but after speaking to 3 different companies they couldnt do these type of GT punto.
After much research and help from fiat forum, I managed to get a new ECU with the code box, key and barrel. Fitted it in myself and it worked!
Few years on and the key code light goes on/off while stationary. Car now sometimes starts and doesnt. If I leave the car for a while, light goes off and starts. But if I turn off the engine and try again, it doesn't. Funny thing is that when I try to start the car with the clutch down and in gear, when trying to move and stall the car, it sometimes starts. This helps the key code light go off and it then ignites.
I have also changed the coil because I was advised it could be that, but same problem.
Any ideas?? Do you think it could be the ECU again, what could be causing the problem. I was told it could be some intermittent problem or something to do with the relay.
CooL-A
CooL-A
