Old 27-05-2008   #1
glow plug light flashing
Can you help with this NEW fault discovered this car give me problems after problems. I have a 2001 Fiat punto 1.9 JTD. 65000 miles. it start fine , as usual. However within about 20 seconds of starting the little orange coil type indicator light on the dash comes on and slowly flashes and stay flashing all the time im driving i have read it glow plugs the engine dont sound as nice as it did does this mean i need to replace them all or could it be something else
and what would the cost be to replace them
Thanks for your help.
whogiveaffff is offline Reply With Quote Quote
Old 27-05-2008   #2
Loves Boost!
ChrisUK's Avatar
Trader Rating: 1
ChrisUK has donated!
Bartender Champion, Wood Firing Champion
Re: glow plug light flashing
you need to gets your ECU codes read to be sure. But I'd say its just your glow plugs.
ChrisUK is offline Reply With Quote Quote
Old 27-05-2008   #3
just went and had a look to see if i could find where the plugs go but with no joy
but notice the maf sennor was off so put back on dont know if thats got anything to do with it
plug light still flashing but goes off after a min or so
i try without starting and it doing the same thing
just sent wife out for drive as she the one saying it staying on all the time
Old 27-05-2008   #4
^ - Alan - ^
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Hi mate,
That is you glow plug warning light. The flashing means that one or more of the glow plugs are faulty, or the controll unit. If the car is starting fine then i would suggest that it is just one of the glow plugs and i therefore wouldnt worry too much about it. The flashing normally lasts around 30 seconds after then engine is started and then stops.
The glow plugs should not affect the running of the engine, just the starting, and thefrore the ruff running is likely to be something else.
The MAF sensor will not affect this light. Sometimes they are unplugged if the sensor is faulty and the owner does not want to replace the sensor (costs over £100). With it unplugged, the engine will run with a default setting.
Its a bit of a tricky job to change the glow plugs as they are not vey accesable, but not an expensive one.
Hope that helps,
Alan
For RADIO CODES please post HERE
Please make a small (or large) DONATION to the Fiat Forum
a1ant is offline Reply With Quote Quote
Old 27-05-2008   #5
Quote Originally Posted by a1ant View Post
Hi mate,
Hope that helps,
Alan
thanks you clear a lot up i going to give changing the glow plugs a go cheapest i found online was £10 each
Old 28-05-2008   #6
well just incase someone intrested i have found a set of 4 glow plugs for £17.75p inc p+p the brand is wellman and what i have read on the web they are a good brand
Old 28-05-2008   #7
Loves Boost!
ChrisUK's Avatar
Trader Rating: 1
Quote Originally Posted by whogiveaffff View Post
Have they fixed the fault or are they not fitted yet?
Old 28-05-2008   #8
Quote Originally Posted by ChrisUK View Post
its a punto what can i say i order the plugs now the light stop flashing all is well with my punto again
Old 28-05-2008   #9
^ - Alan - ^
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
LOL!! Hang on to them though, as it may be that one or more of them is on their way out and working intermittently. Will save you the hastle of ordering them all again when it does go properly!!
Alan
(G) glow plug light flashing utnut Punto (Mk2/2b) 1 18-01-2008 12:02
(T) Flashing glow-plug warning light OilBurner Marea 3 29-08-2007 23:40
(T) Glow plug light flashing for 60 secs seoras Doblo 9 28-07-2007 12:57
(T) Glow Plug Warning Light Flashing oldbillkane Doblo 6 03-07-2006 08:58
(T) Glow Plug Light Flashing PaulE Marea 2 22-07-2005 18:22
