A AY786 Member Joined Apr 4, 2008 Messages 242 Points 82 Location West Yorkshire Apr 30, 2008 #1 If i buy 5mm wheel spacers for a punto sporting mk2 with the normal sporting alloys on them, would it be ok to use the original bolts or would i need to purchase some special ones etc
dannygp Wish mine was a T-Jet :( Parked in the garage Joined Sep 25, 2007 Messages 3,445 Points 501 Location York Apr 30, 2008 #2 You should get the longer wheel nuts with the spacers
dave ****** Parked in the garage Written 10+ guides Joined Aug 10, 2003 Messages 125,246 Points 24,395 Location Essex/Suffolk border Apr 30, 2008 #3 you dont need spacers for standard alloys, they are alread at the correct offset for the car
OP OP A AY786 Member Joined Apr 4, 2008 Messages 242 Points 82 Location West Yorkshire Apr 30, 2008 #4 i know but i wont a wider look for the car - what size bolts would i need exactly?
dave ****** Parked in the garage Written 10+ guides Joined Aug 10, 2003 Messages 125,246 Points 24,395 Location Essex/Suffolk border Apr 30, 2008 #5 30mm should do it
S shorty08 New member Joined Apr 23, 2008 Messages 58 Points 17 Location heysham Apr 30, 2008 #6 with runnin spacers it will put more strain on the wheel bearing thus will need renewing more frequent.
OP OP A AY786 Member Joined Apr 4, 2008 Messages 242 Points 82 Location West Yorkshire Apr 30, 2008 #7 i dont think 5mm will affect it too much and soon i will be looking to get some alloy wheels (17") so it should be ok then as well, i hope Can anyone recommend me some actual size bolts to use?
Rockbottom Steve Parked in the garage Joined Mar 3, 2006 Messages 1,341 Points 188 Location Bristol Apr 30, 2008 #8 AY786 said: Can anyone recommend me some actual size bolts to use? Click to expand... Measure the bolts you have at the moment and get ones that are 5mm longer.
