mickh New member Parked in the garage Joined Aug 19, 2007 Messages 16 Points 7 Location dudley Jan 28, 2008 #1 Cant get the lever out of park.Any ideas gratefully accepted.
dave ****** Parked in the garage Written 10+ guides Joined Aug 10, 2003 Messages 125,246 Points 24,395 Location Essex/Suffolk border Jan 28, 2008 #2 is it a mk1? is you foot on the brake? there a bit on a mk1 to poke your key through to remove the stick lock
OP OP mickh New member Parked in the garage Joined Aug 19, 2007 Messages 16 Points 7 Location dudley Jan 28, 2008 #3 dave said: is it a mk1? is you foot on the brake? there a bit on a mk1 to poke your key through to remove the stick lock Click to expand... Cheers.I,ve just worked out (after pulling it apart)that if i lift the ash tray cover,i can push the plastic bit down to release it.Not ideal,but it will have to do.Thanks again.
OP OP mickh New member Parked in the garage Joined Aug 19, 2007 Messages 16 Points 7 Location dudley Jan 28, 2008 #4 UPDATE....it was the solenoid connection.Now it works as it should by foot on brake as you said.Cheers.
