Thread Tools
Old 22-01-2008   #1
windscreen wiper failure!!
ok problem is the driver side windscreen wiper has stopped workin!the wiper itself has become detached under the bonnet this happened before and i jus clipped it back on but now it no longer stays on any help appreciated guys!
Stone_one is offline Reply With Quote Quote
Old 22-01-2008   #2
just can't get enough
toad101's Avatar
toad101 has donated!
Re: windscreen wiper failure!!
if you've got a mk2 this might be of some use
http://www.fiatforum.com/punto-techn...e-30-20-a.html
toad101 is offline Reply With Quote Quote
Old 22-01-2008   #3
yer mk2b i got!!yer sounds like jus what i need any ideas of a temprary fix till this arrives as the weather aint too good to be without one!
Old 22-01-2008   #4
Rossi's Love Child
rover220 has donated!
apparently, you can remove the drivers wiper and reposition the passenger one so when parked it points up thus wiping the drivers screen when turned on. not my idea, someone on here mentioned it, so dont know if itll work.
rover220 is offline Reply With Quote Quote
Old 22-01-2008   #5
Trader Rating: 10
dave has donated!
Quote Originally Posted by rover220 View Post
if you mean me, ive not tried it, it was just an idea.
ive just had delivered one of the new kits to try on mrs daves car, so may try my idea first just to see if it works
“What is right is not always popular and what is popular is not always right.”
Albert Einstein.
Old 22-01-2008   #6
Misseys Stalker!
vtec has donated!
theres a little plastic ball joint in that linkage, if thats whats failed then go to a fiat garage and see if they sell that on its own, if not go to a scrappy,., it'll cost very litle.,
vtec is offline Reply With Quote Quote
Old 24-01-2008   #7
am i right in thinkin the wipex kit is fir single wiper conversion??also easy enough job to do myself i'm guessin??
Old 24-01-2008   #8
Trader Rating: 10
dave has donated!
Quote Originally Posted by Stone_one View Post
they do do a single wiper conversion, but here we are just talking about up graded linkage to replace the broken ones
Albert Einstein.
Old 24-01-2008   #9
Trader Rating: 10
dave has donated!
Quote Originally Posted by vtec View Post
who what where? all the balls are metal
Albert Einstein.
Old 24-01-2008   #10
Davie Thistle has donated!
..this happend to me a wee while back,
all I did was get a coupla allumimum circ-clip? fingy's
you know the one's that are opened at one end, and you squeeze
them over the narrow fitting between the ball and the wiper arm,
sorted!
Davie Thistle is offline Reply With Quote Quote
Old 24-01-2008   #11
thing is the ball seems to be so worn it doesnt actually hold the arm on so i'm guessin that wont work!seems like gonna hve to get new ones! cheers anyway guys!
Old 05-02-2008   #12
I had this exact problem on the mrs punto.
I fixed it by removing the mechanism which was quite straight forward then drilling a small hole in the middle of the metal ball joints then screwing self tapping screws and a large washer to retain the mechanism in place.
I've prob not described it very well but it was quite an easy and cheap repair which worked well until the wind twisted the drivers side blade off the other day...
Tip
Tipowski is offline Reply With Quote Quote
Old 09-02-2008   #13
Netherlands
I used the (very cheap) jubilee clip solution someone posted here a long time ago - just put the arm back on and fit a jubilee clip underneath it. I bought a jubilee clip that can be tightened with your fingers rather than a screwdriver as it's probably not the easiest place to access wth a screwdriver. It's been on almost a year now without any problems. I do have a spare ready in case the other wiper goes!
punto.nl is offline Reply With Quote Quote
Thread Tools
(T) windscreen wiper motor dnLcal Uno 7 01-08-2007 20:13
(T) Windscreen wiper motor problem Thomas P Uno 10 23-08-2006 20:04
(G) CLX Front windscreen wiper problem delerium Panda (Classic) 15 28-07-2005 11:53
Windscreen wiper The Negotiator Lets Talk FIAT 15 04-02-2004 16:10
