caprimancars
- Dec 28, 2007
- 7
- 4
Hello
My wife has a 2004 1.3Mulijet TD Punto. When the car is started from from cold fisrt thing in the day, all the dashboard lights go out including the clock. When the car has started the clock display will have reset to 0:00 and will be flashing. The car is started correctly, key turned to ignition, wait till the glow plug light goes out, then turn to start. At thsi point the entire dash goes dark while the engine is cranked. The engine cranks quickly and fires quickly. The battery is good as the car was recently left outside for 10 days in the cold weather without being started, after 10 days it cranked quickly and fired up straight away.
I have checked to see if there are any loose wires on the battery, they appear OK (it was rainning when it checked, so it was a quick check).
Could this be a relay problem?
Any advice is welcome?
Many thanks
Many thanks
