FIAT Auto Specialist Team
Thread Tools
Old 12-12-2007   #1
davybreen has donated!
Leaking gearbox seal
Hi, I own an 03 1.2 8v punto, and I have been having trouble with a leaking clutch housing after getting a new clutch fitted. problem is I ve now been told the gearbox seal is leaking into the clutch housing and that you cant get a replacement seal you have to get a new gearbox. Is this correct?
Davy
davybreen is offline Reply With Quote Quote
Old 13-12-2007   #2
Re: Leaking gearbox seal
the seal CAN be replaced.but I think it fits from inside the gear box.
multipete is offline Reply With Quote Quote
Old 13-12-2007   #3
Moderator
ChrisUK's Avatar
Trader Rating: 1
ChrisUK has donated!
Bartender Champion, Wood Firing Champion
Yeah if what they say is true the gearbox needs stripping down and seal(s) replacing.
ChrisUK is offline Reply With Quote Quote
Old 13-12-2007   #4
Bravo 1.8 HLX FTW
The Sultan's Avatar
The Sultan has donated!
Quote Originally Posted by davybreen View Post
Davy
what a load of rubish
i hate dealers that lie thou there front teath
the seal is fit from the inside of the box but it is the easiest box in the world to strip and rebuild ever so wont take long
it should take no longer than 2 hours to do it start to finish box in and out the car also strip down and rebuild is half an hour tops
might aswell have both drive shaft seals replaced also and the rest of the box is sealed with 0 gap sealer
the seal is most definitely available from fiat along with every other part of your gearbox that's for sure
the 541 box features in many fiat cars these days so why would it not be
when the clutch went did it start to slip causing allot of heat hence the seal failure
if the dealer you are using does not want to strip the box they obviously don't know how or there just being lazy so i would go find another fiat garage to do it
most dealers have someone that has been trained buy fiat to strip these box's
intact if you spend long enough in a fiat garage you all learn soon
i know in great detail how to do it
500 door handles fit bravo well chuffed
The Sultan is offline Reply With Quote Quote
Old 13-12-2007   #5
Moderator
ChrisUK's Avatar
Trader Rating: 1
You can come and do my 6 speeder .
Old 13-12-2007   #6
Bravo 1.8 HLX FTW
The Sultan's Avatar
Quote Originally Posted by ChrisUK View Post
i could talk you through it it's that easy
same as the 5 speeder just a bit longer
Thread Tools
(G) 1989 gearbox gears/oil Ross42 Ducato 2 23-07-2008 06:50
(G) Joy... New gearbox Mickey2002 Stilo 9 22-10-2007 02:25
Letter of complaint to Fiat Carbontm Garages 36 11-08-2007 10:41
(G) Addison Lee Ulysse - Gearbox Probs- Taqman Ulysse 6 05-02-2007 14:37
(T) Gearbox Failure! stilomalta Stilo 1 24-08-2006 20:21
