Styling Spoiler Issues / Problems.
Cellgm
London
right i bought a rear window spoiler that sticks on the window.. it looks neat =D
but i am having trouble choosing the best way to stick it on.. or screw or drill it thru the window.. iam not sure ..
any tips?
thanks.
halfrauds do a really strong glue.. but with all the bumps in london.. i think its gonna fall off... =\
what plane did you get that off, lol
be careful when using glue as this can also shatter the glass when it freezes
try a body shop they should be able to attatch it properly at it shouldn't cost much, plus if it then falls off you can blame them :devil:
and it was an f16 carrier jet..
i picked it up when it fell out the sky =\:yum:
Make sure you attach it correctly if it falls off underload and you loose rear down force at high speed the result could be er...cant do it *bursts out laughing* sorry but no!
there is a special tool that is used for them type of spoilers that drills through the glass perfectly without shattering it. i will find out what exactly it is and let u know. he fitted a spoiler to a saxo through the window and it was amazingly strong
Windscreen sealant would prob. be the best thing as it is a bit
flexible and sticks like s**t to a hairy blanket.
i got something called supersteel
it apprently. can help lift a car from a rope. when its dry =D
from halfords 6.99 :*(
