Lamps by Post - For all your lighting needs
Thread Tools
Old 16-11-2007   #1
punto gear linkage problem
Hi, im new to the forum ,
im looking for a bit of help for my dads Punto its an 8v on a 53 plate, he phoned me up last night to tell me his car wouldnt go into any gear and that the gear stick was just kind of "wobbling" about.
i think it has to be the gear linkage so my question is ..what is the best/easiest way to get to the gear linkage on a punto and is there anything i should look out for problems etc...
thanks for looking and thanks for any help
mckeown.thomas is offline Reply With Quote Quote
Old 16-11-2007   #2
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Re: punto gear linkage problem
Hi mate, and WELCOME TO THE FORUM!
If its a problem with the linkage at the gearbox end, then remove the bttery, and the battery tray (only held on with 3 bolts at the botom) and then look down towards the back of the gearbox and there you will see the linkages. Its likely that one of these may have popped off.
What engine have you got?
Hopw that helps,
Alan
If you see a problem post, please click the report button
a1ant is offline Reply With Quote Quote
Old 16-11-2007   #3
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Heres a diagram (i am assuming you have a 1.2 16v or similar)
Hope that helps mate,
Alan
Old 16-11-2007   #4
Quote Originally Posted by a1ant View Post
Hopw that helps,
Alan
hi thnaks for that, im sure its a 1.2 8valve
it defo sounds like linkage problems because of the gear stick just wobbling around or could it be something else
Old 16-11-2007   #5
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Do you know if it is just wobbeling from left to right or front to back or both? (if that makes sense lol)
Alan
Old 16-11-2007   #6
Alan
its moving all over, cant engage any gears. i just phone him there he says it fells as if you could pull the gear stick right out, dosent feel connected to anything if that makes sense
Old 18-11-2007   #7
Bravo 1.8 HLX FTW
The Sultan's Avatar
The Sultan has donated!
Quote Originally Posted by mckeown.thomas View Post
8v and 16v have same gear box linkages
well i cant imagine both cables pooping off at the same time
so my guess is the bracket holding both of them in place on top of the gearbox has shed it's bolts on the road
or the metal pintle inside the gearbox that moves the selector forks may have broken off
these are both as likely as each other so have a look on top of the box and make sure there's nothing lose and if so it's got to be the little pintle
500 door handles fit bravo well chuffed
The Sultan is offline Reply With Quote Quote
Old 01-04-2013   #8
AlexxxJH has donated!
hiya, I am having this problem, its only wobbling up and down. I have a feeling it is the gear linkage. Wondering what would be the easiest solution?
AlexxxJH is offline Reply With Quote Quote
Old 26-12-2013   #9
Today is boxing day 2013. My mk2b Punto has the same problem. Went Christmas day. Had the car on stands and linkage is connected at both ends of the cable.
I cant see the cable inside but was hoping it had just come off. I have a strange feeling the cable may be OK but just cant understand it. Its the Front and back movement of the gear stick which I believe is the bottom end of the 2 connections on the gear box.
Any help please?
Thanks.
fiatbravodriver is offline Reply With Quote Quote
Old 26-12-2013   #10
Mexico
Quote Originally Posted by fiatbravodriver View Post
Any help please?
Thanks.
yes
First time i saw this then with an asistant moving the gear stick you could see the linkages moving so assumed it was an internal gearbox problem
unfortunately what it was or fortunately it was indeed the cable,the best way to prove it is to disconnect it from its ball on the top of the gearbox and while you assistant holds the gearstick tight see if you can pull the cable in and out
i bet your sweet bottom dolla you can
the cable you are interested in is the one WITHOUT the black square adjuster on top of it as this is the side to side adjuster rather than the gear selecter one
Easiest solution is a s/h linkage set from a breakers but beware its an unknown quantity that could work till hell freezes over or a week next tuesday,look to be paying 25 to peruse one
Likes fiatbravodriver liked this post
s and b is offline Reply With Quote Quote
Old 27-12-2013   #11
Thanks for such a quick reply earlier s and b. I've taken some photos will upload tomorrow. It appears both cables are attached both ends.
Luckily if anyone else gets stuck like I did you can just select the gears manually by pulling on the block that the lower cable connects to at the gearbox.
Obviously don't do this with the engine running. Start it with the clutch in and if your lucky like me you may get 3rd. Drove the car to a garage and posted the key with a note ready for when they open. As it's Boxing Day evening very little traffic.
Will update soon. Take care all.
Old 27-12-2013   #12
Mexico
you have to tug them hard
be aware new cables arent cheap and your local garage may be loathe to fit second hand
i dont know your finances but i think new cables are 90
Old 28-12-2013   #13
Car all sorted thanks to an amazing local mechanic.
For anyone that has this problem in future for me as user S and B suggested it was the cable. It went ping when going from reverse to first Christmas day morning.
Its the left hand cable that controls the up and down movement. The is on the bottom half of the gearbox. Although I could move the gear stick by pulling on the cable it was confirmed as broken.
My punto is a 188 mk2b 2005 1.2 8v and the cable part number is : 55186856. This part number replaces 55194775. On my car the part numbers were printed on which helped.
My local main dealer had one cost 107.42. Ebay is your best bet as they are half this but I was desperate to get it repaired as I am back to work Monday. Otherwise would have been a few days wait. The fitting cost was 50.
Best Wishes and Happy New Year to All.
Thanks oldhammer thanked for this post
Old 29-12-2013   #14
My 2004 Punto is having problems with gear selection, I cannot get into second without a good pull on the gearstick, first is less tight, but goes in, reverse is really hard too. Have verified the clutch is ok, but have read it's likely corroded at the gearchange end, under the car at the end of the cables.
Going to try WD40 there tomorrow, hoping it might give some temporary assistance, but believe I may have to sand off some corrosion on a pin there.
Anyone else think this a likely cause?Have to drive my two young children 100 miles on Tuesday, so really hoping I can make this trip, then do the job properly on my return.
So hope someone can concur?
Many thanks
Matt
Puntopunter17 is offline Reply With Quote Quote
Old 29-12-2013   #15
Sorry dont think I can be much help but I would go careful with the gear changes as you dont want a snapped cable like I had.
When mine went Xmas Morning, I jacked the car up and put it on axle stands. Got under the Gear selector and there are 5 screws that are a ribe/torx head Id say a t10 then the plastic cover comes off.
It looked like this on mine.
If you wanted to you could check the condition of your car and use these photos to compare.
While under the car I also noticed this cable runner to have come out. It was a pain to get back in.
Good luck.
Thread Tools
(G) How many Puntos are there on the Forum? - The Thread FiatStiloJTD Punto (Mk2/2b) 543 06-06-2008 17:15
