gsrausse
I have a W plate punto that has just started overheating. I bled the radiator and topped the system up with water/coolant. This worked fine for a day or two then the problem re-occured. I decided to book it into a garage to see if they could see the problem, I thought it was the thermostat sticking on closed but they have come back saying the head gasket has blown. To my knowledge if the head gasket blows I would have water in the oil causing a milky soloution. But there is no sign of this, are the garage conning me into replacing the head gasket when actually it is only a simple fault.
p.s the heater will not blow hot even when car is heated up, also car has only done 23,000 miles
