Thread Tools
Old 10-06-2007   #1
Question Changing mk2 jtd alternator?
can anyone help me? How on earth do you get the alternator out of a Punto Mk2 jtd engine compartment. Can anyone talk me through the route and method as the bearings are squeeking and I need to get them replaced. There is no Haynes manual to cover this model.
Thanks in advance... Ed
Ed the duck is offline Reply With Quote Quote
Old 10-06-2007   #2
Re: Changing mk2 jtd alternator?
With extreme difficulty unfortunatley, Hgt is a similar setup and I found the best way was to remove the wheel and arch liner plus have it up on stands to get access from beneath. Its still very hard to get to everything but is possible.
Good luck
DanGil is offline Reply With Quote Quote
Old 10-06-2007   #3
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Yea, as above! Its a git because its very tight, but remove the drivers side wheel and inner plastic arch. You also need to undo the 3 bolts attatching the rigid engine mount to get to the bottom alternator mount!
a1ant is offline Reply With Quote Quote
Old 11-06-2007   #4
Thank you both, shall try this weekend.
Ed.
Old 12-06-2007   #5
Donate Donate Donate!!!!!
Jasperado has donated!
Are you sure it's not just the belt needing a bit more tension?
If your reading this you should donate!!
Jasperado is offline Reply With Quote Quote
Thread Tools
(G) How many Puntos are there on the Forum? - The Thread FiatStiloJTD Punto (Mk2/2b) 543 06-06-2008 17:15
