| | Guide Tools | Search this Guide |
Posts: 11 Thanks: 1 Trader Rating: 0 | If you don't have an impact gun, and you must use classic tools (socket with some heavy extension bar), car should be still on all 4 wheels when you are trying to loose the nut (32 mm). If it's done (nut is loosened), then take wheel out. First you must loose the shoes self-adjuster. Shoes can hold the drum (despite of rust on central hole). Through the wheel screw hole in drum, you can loose it using screwdriver or something like that. Find it, push it, and shoes will move out away of drum. ![]() When you have removed the small drum (12 mm hex) bolts (M8 threaded), there will be threaded holes in the drum itself. There's M10 normal thread. You can take off drum using bolts screwed in (it will act like puller/separator). Drum will be pushed away from hub. ![]() Or you can use slide-hammer (don't buy fancy tools, improvise, like in this example, it's body-building weight) and knock the drum off (a bit better than punching drum with regular hammer). ![]() BTW, rear hub for Punto is the same as for Bravo/Brava (1,4 1,6 and diesel 1,8). This is example of rear hub replacement job (not Punto, but procedure is the same). Rear hub bearings are double-row ball type. There is no clearance setting (like in cone roller bearings). Just make it real, brutal tight (long extension bar or good, strong impact gun), torque wrench in not necessary here.
Last edited by pmx007pl; 30-11-2012 at 08:23. Reason: Pointless usage of torque wrench. | ||
| | Quote
| Currently Active Users Viewing This Guide: 1 (0 members and 1 guests) | |
| Guide | Guide Starter | Category | Comments | Last Post |
| | Daver | Grande Punto | 16 | 27-05-2011 10:23 |
| | rab10000 | Multipla | 1 | 11-08-2009 18:52 |
| | Alan.D | Panda (Classic) | 6 | 31-10-2005 12:21 |
