Lamps by Post - For all your lighting needs
View Poll Results: Was this guide Helpful?
Yes 6 100.00%
No 0 0%
Voters: 6. You may not vote on this poll
Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Mk1 ignition live to cd player<!-- google_ad_section_end -->
Published by wilko1992
30-05-2011
Unrated
User Rated:Unrated
A 30min installation guide on how to Get your cd player to tun off with the ignition key in MK1.
Tools required: Snips, Wire strippers, Crimping tool, Crimping bites i.e. straight connector and bullet socket, Length of suitable wire (I used the live out of some 2core 240v 0.75mm flex),Allen key 3mm, And this guide
1. DISCONNECT THE BATTERY
2. Now remove the 3 screws holding the plastic trim underneath the steering wheel using a 3mm Allen key.
3. On the left hand side or the steering wheel there is a white plug with 4 wires unplug it.
4. There is a blue and yellow wire in the plug (see pick as its the one i have separated)
5. Cut the blue and yellow wire about 3" from the plug and strip the ends revealing the copper and crimp a straight through connector onto the bit of wire thats still connected to the plug. Then get your new bit of wire and strip the end of it revealing the copper and twist onto the other half of the blue and yellow wire and insert into the other end of the crimp and crimp shut. Or solder them and heat shrink it if you prefer doing it that way.
6.Cut your new bit of wire to length and crimp on the required end to connect to the live on your cd player (In my case a bullet socket)
7. Then plug into the live on your cd player and plug the white plug back into the ignition barrel re connect the battery put key into ignition and turn on.
8. Now your cd player should come on and off with the ignition .
9. Now to tidy away the new cable running from your ignition to your cd player and screw back the plastic trim underneath the steering wheel.
Hope this helps you
Likes AlexDMegara liked this post
Old 01-06-2011   #1
Re: Mk1 ignition live to cd player
hello wilko
Thanks for the excellent info. Could you please confirm whether it will work on the fiat punto mk2 8v exl (w 2000). There is another method which uses the ignition wire (red). Would there be any difference between these two?
Thanks Wilko
gadlad is offline Reply With Quote Quote
Old 01-06-2011   #2
wilko1992 is part of the official FF Events Team :)
wilko1992 has donated!
Hi glad u approve of my guide not shure on the mk2`s wiring best thing is to follow this guide but before you cut anything get a multi meter and test witch wire powers up when you turn the ignition on
Quote Originally Posted by JustAndy View Post
The faster you go the louder it gets! Thats what i like haha
wilko1992 is offline Reply With Quote Quote
Old 05-06-2011   #3
Hey Wilko
Good idea. will follow that n keep u updated
Thanks Wil
Likes wilko1992 liked this post
Old 23-11-2011   #4
Netherlands
Guys,
I got the 1.2 16v ELX, thsi punto is from november 1999, Does this guide aply to my car??
thx Rick
Rickyklu is offline Reply With Quote Quote
Old 30-11-2011   #5
if its a mk1 then yes as for a mk2 then not shure but if you foll the guide and just frind the ignition live on the barral connectors
Old 05-02-2012   #6
Romania
Hi wilko1992! Awesome guide you made!
I have a question: after I link the ingnition to the player, will I be able to turn the player on with the ingnition off? Thanks!
Ovidiu176 is offline Reply With Quote Quote
Old 05-02-2012   #7
now with added gold
custard's Avatar
Trader Rating: 1
custard has donated!
read point 8
Old 05-02-2012   #8
Romania
Yes, I've read the point and got it. You turn the ignition off, the player goes off. Afterwards will I be able to turn the player on, without turning the ignition on, when I'm stationary? Will it have power to it? That was actually my question.
Old 11-02-2012   #9
no it wont come on with out the ignition on thats the downside, but if you realy want to i put a 3way switch (ignition-off-perm live) in my glovebox so i can still turn it on when sat in the car at club meets ect
Old 12-02-2012   #10
Romania
I see... Can you explain a little bit how you wired the switch, please?
Comment
Search this Guide:
(T) ignition live jonbrunt Punto (Mk2/2b) 3 14-07-2010 13:06
(G) ignition live vees punto Punto (Mk2/2b) 4 22-03-2009 11:36
(T) Ignition Live need in Punto 04 warree01 Punto (Mk2/2b) 2 01-07-2008 20:29
(G) Ignition controlled live dozydozer Bravo / Brava 1 24-03-2007 12:38
Mk1 Ignition live badboy I.C.E 14 29-08-2005 21:45
