Become our fan on Facebook
Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Heater dial colour change, mk2 punto<!-- google_ad_section_end -->
alittle heads up :)
Published by Azzam
06-04-2011
Unrated
User Rated:Unrated
orite guys and gals
here im gna show you how tochange the colour of the heater dials, heres what you need:
Allen key to remove the 4 screws
type 286 bulbs(any colour) i got white
reflective tape,
screw driver
nail varnish remover
4x cotton swabs
small pliers
heres what to do, on the bottom passenger and drivers foot well of the center console, undo the Allen screws 1 per side.
now undo the screws in the center under the ash tray, these are also allen key screws.
now pull the bottom of the center console and then the top unclips
now you have the center console out, pull the dials out (they might be alittle tight but just pull them!)
now look at the back you will see this.....
prise the white plastic trim off with a flat head screw driver....... it also has 3 clips at the top, just push them in and gentlt prise it off. you will see the logo's of the heater control with a orange film. now get some nail varnish remover(ONLY USE ALITTLE BIT!). Get the cotton swab and just gently rub the orange film off, DONT GO THROUGH THE WHITE FILM! once the orange film is off put the plastic trim back on, you can glue it back on but i didnt bother because its strong enough without glue.
now that you have the dials off you can now gently grip the bulbs with the pliers and pull them out and replace them, note that led's are polarity concious, if the bulbs dont work take them out and turn them 180 degrees and see if they work.
heres the bulb on the top im changing it to.....
Now put the LED's in
you're nearly finished! now get some reflective tape (i bought mine from a local DIY shop)
and cover as much as you can for a more even shape on the signs!
now assemble everything together!
Just the reverse of removing them.
thanks for watching and good luck!
Now it matches my dash beautifully, ill upoad a pic when it gets dark! :P
Thanks OllieSavage thanked for this post
Old 21-04-2011   #1
Re: Heater dial colour change, mk2 punto
tried doing mine a coupla days ago and couldn't work out how to get the orange off and only just found this guide i tried using a scalple but just scratched right through do you know where i could get new dial sets?
OllieSavage is offline Reply With Quote Quote
Old 01-05-2011   #2
do you have a link for the bulbs?????
cheers
craigs3tdd is offline Reply With Quote Quote
Old 03-05-2011   #3
I Have Done This To My Car It Is Looking Good. But I Am Wanting To Change The Bulbs For Behind The City Button And The Windows Etc. I Am Not Sure On How To Take The Top Bit Of The Centre Console Out??
Any Help Would Be Much Appreciated Thanks Kirsty x
Punto1990 is offline Reply With Quote Quote
Old 03-05-2011   #4
Deekstar has donated!
top bit with the buttons on is secured by 2 hew screws they under the main bit when u take that off, although to change the lights you need to resolder leds in
Deekstar is offline Reply With Quote Quote
Old 03-05-2011   #5
Yeah I have took it apart again and it needs soldering Dam!
Thanks Kirsty x
Old 04-05-2011   #6
Hi kirsty!what colour did you want to change your switches too?iv got some blue 1s for sale if interested?
siadz is offline Reply With Quote Quote
Old 04-05-2011   #7
Azzam has donated!
To get a new set of dials, i would try a scrappy, they always will have a mk2 punto hiding somewhere :P
i just used fleabay heres a link for the bulbs : http://cgi.ebay.co.uk/2x-WHITE-T5-286-Ultra-Bright-Dashboard-LED-Bulbs-/220745084814?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item33656eaf8e
for the window switches and buttons i use this site:
https://www.crazyleds.co.uk/home.php?cat=57
i think you need 6 l.e.d's but unsure
just choose what colour you want!
and erm when you re soldier the new l.e.d's make sure that you dont over heat them, use a 25watt soldiering iron like i did and make sure that all the slodiering joints are clean and neat as these are very sensitive. Oh i almost forgot make sure you get them the right way around! :P
sorry about the blurry pic, this is wat she looks like now.
Subtle but in your face.
Azzam is offline Reply With Quote Quote
Old 23-05-2011   #8
hi, it tried this the weekend. i did the whole shiny foil thing, and changed for blue bulbs, but they are very faint and i cant see them. I took all the orange off the insides too, would it be better with clear white bulbs??
Help please as i cant see my heaters at night. :L ,
CJBate is offline Reply With Quote Quote
Old 27-05-2011   #9
Quote Originally Posted by Azzam View Post
hi azzam,did you have any problems with the bulbs?iv got the same ones but in blue but they were really loose in the sockets and keep falling out?
Old 07-04-2012   #10
Gibraltar
Question Re: Heater dial colour change, mk2 punto
yo dude great guide,
only problem is that i tried gettin the orange off the films with nail polish remover but no luck at all. what kind of nail polish remover do you use because the one i got aint working at all.
cheers
JahCulture is offline Reply With Quote Quote
Old 29-04-2012   #11
Azzam has donated!
hi everybody sorry i forgot i made this post!
im gettin old lol erm blue is not a very reflective colour so you can either get a higher wattage bulb or use bright white.
I had no problems at all installing my bulbs, nice and snug fit.
Also try using a light coat of 2k paint thinner and see if that works
Old 19-05-2012   #12
Romania
Hi
Sorry for my poor English
For the Heater I use 12VDC LED Strip. 5 piece. Easy to glue inside. Electrical power from one bulb.
Mike
Name:	b 2012-05-04 21.09.16.jpg
ID:	103218   Click image for larger version
Name:	c 20120518_215237.jpg
Name:	d n91cx_unlit.jpg
Mike60 is offline Reply With Quote Quote
Old 11-10-2012   #13
Spain
Quote Originally Posted by Mike60 View Post
Hi
Mike
thats brilliant mike
literally
s and b is offline Reply With Quote Quote
Old 07-11-2012   #14
Israel
hello,
i couldn't find the screws in the center under the ash tray.
i have MK2B, with CVT 2006.
help please...
chenrp is offline Reply With Quote Quote
Comment
Search this Guide:
(S) fiat seicento heater dial facial andy3030 Cinquecento / Seicento 8 20-07-2010 12:57
(T) punto mk2 dial removal bluepunto2 Punto (Mk2/2b) 3 05-02-2009 19:41
(T) Heater dial Niall1717 Cinquecento / Seicento 1 31-05-2007 14:17
(G) Heater Controls and Dial Templates Needed SkinzCinqSporting Cinquecento / Seicento 10 23-04-2006 12:16
(S) Changing Mk2 Punto Dial Bulbs darkcircuitUK Punto (Mk2/2b) 14 09-05-2005 15:31
