Lamps by Post - For all your lighting needs
Comment
Guide Tools Search this Guide
Resoldering Power Steering Motor Relays
try this before replacing motor/column
colinf1
22-03-2011
To check the solder joints you need,<br />
<br />
<div align="left">Allen key - 4mm <br />
Torx bit - T7 or T6 <br />
Soldering iron<br />
Soldering wire<br />
A steady hand<br />
A good light source<br />
<br />
1 - Take off fuse box cover<br />
2 - Take of bottom steering cowling<br />
3 -
Old 13-08-2011   #15
Re: Resoldering Power Steering Motor Relays
Quote Originally Posted by graham964 View Post
Thanks Sab very helpful as is the whole post. My sons car has had this intermittent fault which I originally cured by simply cleaning all of the conacts on the ecu by scraping them with a scalpel and this seemed to cure it for a couple of months but its failed again so I have bought an elm327bluetooth (which should arrive in a couple of days) and downloaded Fiatecuscan and will do the resoldering and check the relays to see if this solves it, I am not sure that I understand what to do with respect to calibrating. I assume Fiatecuscan guides you through the process. I will also read the fault codes.
Thanks to you as well Forest 159 for a great guide. Given that this problem is so common I would have thought this should be made into a sticky
cheers
Graham
If you get stuck just message me but its straight forward re-calibrating as long as the engine is running and steering wheel is straight.
cheers Chris
forrest159 is offline Reply With Quote Quote
Old 17-08-2011   #16
Portugal
Quote Originally Posted by forrest159 View Post
You can try the re-solder but from experiance it will keep going faulty unless you re-calibrate the torque sensor and steering angle sensor because you are removing the motor from a set position.
Give it a go though you have nothing to lose ?
cheers chris
it only needs calibration when the column is changed..
if only the motor is removed even if the position changes the ecu will recalibrate after a few miles of driving.. i've repaired quite a few and never bothered to recalibrate (i have the means) and they all work fine
smokeme is offline Reply With Quote Quote
Old 08-01-2012   #17
I have just done this
After two days of working on it i just put it back in my car and it worked. Soo happy.
Thanks to everyone who posted information!!!!
amicallef is offline Reply With Quote Quote
Old 08-02-2012   #18
Hey
Can I ask did they stop putting the relays in later models mine is an 03 reg and wondered if this was a possible fix or not?
All help much appreciated
footychick15 is offline Reply With Quote Quote
Old 08-02-2012   #19
Portugal
Quote Originally Posted by footychick15 View Post
Hey
the basic system is the same, just a bit more reliable so far... probably improved quality control
Old 09-02-2012   #20
Thanks for the reply so would you advise giving this ago first before forking out for a new column?
Old 09-02-2012   #21
Also what relay do I need to buy is there a code or something I should be looking out for?
Thanks again
Old 09-02-2012   #22
Portugal
the error code will give you clues to the cause, bad solder joints and dead relays will usually give low voltage errors.. if the error is torque sensors then it's a new column since it has no known repair yet..
Old 19-05-2012   #23
Malta
[QUOTE=sab8th;2825335]The power steering failed on my daughter's Mk2 a couple of weeks back. I ran through the advice in the first post resoldering all the relay joints, but to no avail - the damned thing still wasn't working. I checked the relays with a meter and discovered that one was faulty - it had shorted![QUOTE=sab8th;2825335]
I have this same problem. "CITY" on the dashboard is still on and a steering wheel light came on. Can this indicate the source of the fault? I am new to this sort of thing although I had an 1100 (bless her) before. No gimmicks etc. So I have to be sure without going to all this hassle. Thanks guys...
Very helpful this forum.
grech is offline Reply With Quote Quote
Old 23-05-2012   #24
Bulgaria
Quote Originally Posted by grech View Post
Same to me. When key is on second position sometimes don't give me error and can change city on/off, but when start engine the red light apears. I will try this manual and post what happened
Mordorito is offline Reply With Quote Quote
Old 05-06-2012   #25
Bulgaria
Works like a charm! I had no need for synchronization. Thank you all for help
Old 14-06-2012   #26
Firstly, this is the reason why I registered as I have this issue on my wife's Car.
Secondly I would like to thank the originator of the post for an excellent tutorial and fantastic step by step guide to how to resolve the problem.
now the question, how difficult is it to get the 3rd Hex head bolt out, ( 1 closest to front of the car) 2 are easily accessible but the 3rd there doesn't seem much space at all. Because the plastic of the dash seems to be in the way .
LeePunyer is offline Reply With Quote Quote
Old 22-06-2012   #27
Bulgaria
You need something like that
Old 01-07-2012   #28
Hungary
Hi! My parents has the same problem on their Punto, the servo is not working, most notably when it is colder, but it also turns off in the summer and hot. The steering wheel red light turns on, there is a click sound, and the servo is gone, the steering is extremely heavy. If I turn off the engine and remove the key, then I turn on again, it usually works again, the red warning light disappears, and the servo is working normally, but sometimes only for few minutes, sometimes for days. There is a strange rattle sound from the steering wheel, especially when it is in the middle, and moved to right and left a little, then it is behaving like the servo motor is trying to calibrate it, if you understand what I mean to say. When I turn it all the way to one side, then it is also rattling and moving a little, usually these are the situations when it turns off. It doesn't help if CITY is on or off.
I went to a garage to check it, but they said it is a common problem, and it can not be repaired, needs to be replaced, which costs very much. I can't remember what part they said that needs to be replaced. Anyway, they did it within 10 minutes, I do not think they have checked anything, jut ran a diagnostics and said replacing all.
Do you think re-soldering the relays might help, based on my description? Perhaps I should immediately buy new releys to replace them? Or it is likely that the car has a bigger problem and needs a more expensive part?
I found this page on a Hungarian forum, are these the relays I need?
lr2a-12w Could you confirm that these are what I need? Since I'm new on the forum, I can not post the link
Many thanks for all your help!
gurabli is offline Reply With Quote Quote
Old 05-07-2012   #29
Would this work with a '06 Grande punto?
Feltham100 is offline Reply With Quote Quote
Comment
Search this Guide:
(T) power steering motor Benny 1992 Punto (Mk2/2b) 6 18-01-2011 13:24
(T) Power steering motor colinf1 Punto (Mk2/2b) 2 17-06-2010 18:03
(T) Power Steering Motor Replacement Cyat20 Punto (Mk2/2b) 4 31-01-2010 18:47
(T) Power Steering Motor and Steering Rack bridgit37jones Panda 2 27-11-2009 15:59
(G) Electric Power Steering Motor Noise? Milamber Stilo 5 19-06-2006 16:19
