Become our fan on Facebook
Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->1.2 16v Throttle Body Removal, Clean and Re-Fit<!-- google_ad_section_end -->
Published by Sqwidge
24-01-2011
Unrated
User Rated:
Difficulty Level: 2
This is written for my 2003 1.2 16v but may possibly work for other models.
You will need:
10mm Socket on a ratchet
10mm inverted star socket
50-100mm ratchet extension
non inverted star key set
CarbCleaner (CC) or brake cleaner
Toothbrush
1. Remove the 3 x 10mm bolts securing the airbox to the engine.
2. Remove and discard the 3 x 'crimp clips' that secure the main intake to the TB (under the ECU), the breather from intake to rocker cover (about halfway down the main air intake) and from pre airbox intake behind the left headlight (looking at car from the front).
3. Remove airbox to reveal rocker cover and put to one side.
4. Unclip ECU plugs but do not pull as there is an earth strap attached and undo 4 x 10mm nuts (the earth strap is located under one of nuts and I also marked one of my ECU plugs to make sure they went on correctly during reassembly) to remove the ECU from its cradle.
5. To remove the TB you need an inverted star socket, I cant remember the proper measurement they use (measured in E something) but I know its 10mm, remove the 4 x inverted star bolts and unplug the single plug connector from its location on the TB.
Be sure to capture the orange 'O' ring.
6. The ECU cradle will now come off with the TB, now the TB is off take it indoors and find yourself an old chinese food tub or similar and spray CC into it till its about 3-4mm deep.
7. Remove the 2 x star screws holding the butterfly in the TB using the non inverted star keys and put into the tub of cc, make a note of which way the butterfly sits in the holder for reassembly, there are two lugs on it so it only comes out one way just remember where these sit when its closed.
8. You don't have to do this but I found it easier this way:
Remove the 6 x clips from the black housing on the TB, nothing will fall out except for a fairly big gear wheel so dont worry although there are some springy electrical connections so be careful not to bend these, once cover is off, rotate the gears so that the butterfly is wide open and hold the whole TB in a fashion so that your palm holds the gears in place to stop it rotating back and remove the butterfly with your fingers, if its stiff grab it with pliers, once removed soak it in the tub of cc.
9. Grab your toothbrush and dip in the tub and then scrub any hardened carbon from inside the TB, mine was pretty bad so spent a fair amount of time cleaning it up until it was shiny like new, make sure its 100% clean then put to one side and clean your butterfly and bolts.
10. When clean, spray cc from the can onto all parts incase there is leftover residue and let air dry, this takes about a minute to fully dry, then wipe with a clean soft rag.
11. Move the gears to rotate the holder and refit the butterfly the same way in which it came out, to make sure when you let go it should close and leave a little gap for the air to get through but you can also push it closed sealing it completely, fit the 2 x little star screws and your butterfly is in.
12. Grab the black casing and check there is no debris etc in it and that the rubber sealing gasket is in good nick and in place then refit using the 6 x clips, they are sprung so fit one side then just push up with your thumb to fit.
13. Check the mounting face on the engine to ensure its clear of debris and then refit the 'O' ring, ECU cradle and TB making sure that the black casing that houses the gear wheels is facing forwards towards the headlights, dont forget to reconnect the plug you took off!
14. Refit the 4 x 10mm nuts along with the ECU earth strap and tighten up to FT (Phucking Tight), then reconnect the ECU cables.
15. Refit Airbox and where you have cut the 'crimp clips' use either Jubilee clips or big cable ties, as there is no real pressure or movement in the airbox or its pipes I used cable ties and have never had a problem.
If your one of these people that likes to 'improve' their electrical connections using WD40 then don't, if you have to do it use the cc as it evaporates but leave it a minute so you dont blow yourself up.
It looks like a long job but it takes about 5 minutes to get the TB out, 15 mins to clean it properly and then 5 mins to reassemble it.
Job done, Simples.
EDIT: When I did mine and then refitted I had an idle issue which turned out to be the butterfly as I had mounted it backwards, once rightly in, I took it for a ten min drive to let the ECU see the 'change' and then adjust everything up and its been bang on ever since.
Whilst your airbox is off its worth grabbing your 10mm and taking the air filter out and giving it a good clean, I found leaves and allsorts in mine lol.
Likes stonesie liked this post
Old 08-02-2011   #1
Noob for life
SamuraiDragon's Avatar
SamuraiDragon has donated!
Re: 1.2 16v Throttle Body Removal, Clean and Re-Fit
can u skip the stripping part and just spray a load of carb cleaner into the throttle body as a complete unit just to "freshen" it up?
SamuraiDragon is offline Reply With Quote Quote
Old 20-03-2011   #2
yeah but it may not shift everything, its best to clean it properly.
I tell it like it is so if I offend you.....Unlucky.
Rule No.1: If it don't fit, make it fit.
Rule No.2: If in doubt, kick or hammer it.
Sqwidge is offline Reply With Quote Quote
Old 27-03-2012   #3
Romania
someone managed to calibrate the Stilo 1.2 16v throttle body with fiatecuscan? in the menu to go I could calibrate ?
preparatul is offline Reply With Quote Quote
Old 18-04-2012   #4
Slovenia
Thanks. It just needed cleaning and it worked! So simple solution to annoying problem. The engine stalled in low revs when pressing the clutch - usually when approaching juntions, parking lots etc.
Didn't even use a cleaner, just a rug, some spit from bottom of my throat and gently scrapped the black residue around the butterfly with a screwdriver...
That O ring that is holding black tube to the TB was made of PVC with locking zipper - whatever you call it. You can't unlock it in order to reuse it therefore you will have to pray it sideways with a scredriver and break it.
Uno mk2 1.0 fire, Punto mk2 1.4 16v, Bravo mk2 Startjet Dynamic 1.4 16v
Karletto is offline Reply With Quote Quote
Old 12-05-2012   #5
My situation seemed even more desperate. F22 15amp blew; fault display throws up dramatic 'engine failure'. Relaced fuse, which got me home. Checked wiring diagram; T9 relay (30 amp) seemed likely candidate; replaced (£13.80 Fiat); engine started, but now lumpy idle. F22 blew within 30 yards of driving, oh dear! Fiat say: new ECU needed (Kerching!) Saw your brilliant post, but didn't have female star socket to move ecu mounting (do now), so pushed open butterfly valve and just squirted loads of CC into intake throat and was amazed at all the black gunge that came out (46K miles). Reassembled; now runs like a dream. My theory is; as valve is motorised and gummed up, it struggled harder to open, drew more current than usual and popped F22. Fiat must know this, but must also do a very nice line in £1000 ecu's. N.B. for the misers out there; the carb cleaner came from a pound shop and had twice the contents of the one from a motorists store that begins with H and sold at £10.99!
Our 2006 Fiat Idea Eleganza 1.4 16v is a brilliant mini mpv and love driving it.
frustrated mech is offline Reply With Quote Quote
Old 14-09-2012   #6
I was told i had an ecu problem but i wasant convinced as i dont always trust garages and it turned out to be a faulty ht lead but prior to knowing this I followed this Guide on cleaning the Throttle body, step by step. Brilliant it is But now i have the high idling between 1500 - 2000, All wires are correctly positioned and Iv'e tried all the reset tricks but to no success.
I Really have 2 questions,
firstly When i did the removal of the TB i Removed the butterfly screws, then thought hmm i better not mess with these and placed the screws back in, (now im thinking ive altered the butterfly position, but im not sure on the correct possitioning or if infact the tightness of the screws etc make any difference? Also i noticed when the butterfly is placed it doesent fully close unless i push slightly and it closes but theres a little spring back, is this normal, thanks
Also i attempted to change the positioning of the Butterfly but as i was turning the star shaped screw it snapped, I luckly have removed the broken part, but i just dont know were to get a replacement screw or what size these infact are.
johnb1976 is offline Reply With Quote Quote
Old 09-10-2012   #7
Romania
Sqwidge: Is it possible to have some pictures? Thx.
blueman07 is offline Reply With Quote Quote
Old 02-01-2013   #8
Ireland
Hi.
I cleaned Throttle Body on my punto.
I put everything back in place it was, then started the car it was running grand for a little while, but then lost all the power i was pressing the accelerator but rmp wot go up.
Then i restored ECU- run the car everything seems to be ok, after about 10 min rmp goes up more than 20k and starts to bounce up and down.
Does anyone know how to solve this problem?
Thanx
R0x0r is offline Reply With Quote Quote
Comment
Search this Guide:
(G) How to give throttle body a clean. Benji10 Punto (Mk2/2b) 3 27-08-2010 15:55
(T) Throttle body removal callumfletcher Bravo / Brava 1 11-08-2010 10:20
Fiat Punto 1.2 16v Mark One Upgraded Throttle Body (Also Cinq Sei 1242/1368 16v) J.R Racing Auction Watch 7 05-03-2009 11:30
(T) MAP sensor fault - but it isn't? [throttle body clean] Steely Stilo 21 01-05-2008 07:22
(T) Clean throttle body - jumpiness gone davemarsh Punto (Mk2/2b) 2 14-07-2004 01:54
