Become our fan on Facebook
Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Fitting A Focus Induction Kit (8v 1.2 Punto).<!-- google_ad_section_end -->
Just fitted mine, now looking to help other users.
Published by Bolted
11-08-2008
Unrated
User Rated:Unrated
Before we start I seriously recommend any members to buy one.
They are EXCELLENT value for money at just over 30 quid.
The car I fitted mine to is an 04 8v 1.2 Punto (Mk2B)
They have made quite a big difference to the sound of my car, and also increased it's economy (although my air filter was blocked I suspect).
Do not try buying these for any other engine other than a 1.2 8 valve (Mk2, and Mk2b both fit).
I'll write a little guide as many members struggle fitted these.
1) Before you start make sure you have every peice of eqipment that come with these kits.
This includes:
Steel tubing.
Blue elbow joint.
Blue circle joint.
Air induction cone (normally blue or red).
A length of thin hose.
1 small hose clip.
Various large hose clips.
2 mounting brackets.
The kit does not include
2 more small hose clips.
A small copper connection. (Can be bought from Homebase, B&Q, etc etc)
2) Once you've got everything you need start by unclipping the small spring which is holding the air filter box on.
Please note - remove the whole black box, do not start unscrewing the top screws. The standard air filter is the whole black box.
After that unscrew the 2 screws now holding the box on.
Then it should just lift up.
3) Join the air filter together trying to follow this image.
Please note the steel tubing should go down towards the engine, not any other way.
Than attach it all together using the large clips.
4) After the air induction kit is built up attach the blue elbow pipe to where the original air filter box was removed, making sure the black seal goes over the blue elbow pipe.
5) Secure that connection with one of the large clips, making sure its secure.
6) Next you'l need some copper piping connectors (not included).
The copper pipe bridges the gap between the blue air induction kit pipe and the whole the orginal air box left.
This should then be secure with 2 smaller clips (one on either side of the connector).
7) Next, attach the other end of the blue wire to the steel induction tubing. Then secure this with a small clip.
8) Now all you need to do is secure it (which is easier said than done as these kits are not specifically designed for a Punto).
Some people connect the brackets that came with the kit to the manifold bolts (under the heat protection metal). Other people secure it to the battery holder.
I secured it to the battery holder, so just go ahead and unscrew the battery holder bolt and slip one of the brackers through there.
Next attach the other end of the bracket to the steel unduction tubing (I used another large clip).
9) Basically this is just touch and go where you can find to attach it, but try and secure it as much as possible and also try to make sure the small blue hose does not touch any metal part of the engine.
10) You're more a less done. Just seel the hole on the back of the elbow bracket up with a small amount of sillicone. Tighten all your clips.
Then just go ahead and fire the engine up.
Hopefully
you'll notice a difference in sound, mpg economy, and power. (But probably not to a great extent).
Please post your results, and comments.
Cheers.
Thanks DeeJayCeee, lilmrwilliams, mcjacko1987, OPotts, Azren0 and 4 others thanked for this post
Old 13-08-2008   #1
I am the STIG!!!!!!!!!!!!
joe-bloggs's Avatar
joe-bloggs has donated!
Re: Fitting A Focus Induction Kit (8v 1.2 Punto).
A good read
Shame it doesnt fit for mine cos it a 16v, but out of curiousity were is the copper pipe thing you connected, and why?
Cheers.
Punto MK2B Active Spt 16v: 15" Chrome BK Racing alloys ¦ SPAX lowering springs 40mm ¦ CAT Back twin exhaust system ¦ Door Graphics ¦ Euro Reg plates ¦ Aero Wipers ¦ Xenon Headlight bulbs ¦ Colour coded mirrors ¦ Ripspeed flip screen DVD player ¦ Kenwood 6x9s in custom carpeted parcel-shelf.
joe-bloggs is offline Reply With Quote Quote
Old 14-08-2008   #2
Quote Originally Posted by joe-bloggs View Post
A good read
Cheers.
Thanks.
The copper pipe is just a normal joint which would normally be used for joining heating pipes and things.
It works by having half of it in the black pipe and half of it in the other pipe forming a bridge across them so they can be clamped at each side and secured.
This means there will be no leaks.
Bolted is offline Reply With Quote Quote
Old 27-08-2008   #3
TomMarv has donated!
Im gonna get one of these now mate.
Which focus induction kit is it though?
TomMarv is offline Reply With Quote Quote
Old 27-08-2008   #4
Captain Mike has donated!
Quote Originally Posted by TomMarv View Post
http://cgi.ebay.co.uk/B-NEW-98-04-FO...d=p3286.c0.m14
Captain Mike is offline Reply With Quote Quote
Old 27-08-2008   #5
naaathaaan has donated!
Thumbs up Re: Fitting A Focus Induction Kit (8v 1.2 Punto).
Do you know if this can be fitted to a mk1 1.1 55 punto?
Cheers!
R.I.P Punto
1.9D CL VW Polo 6N
naaathaaan is offline Reply With Quote Quote
Old 27-08-2008   #6
Quote Originally Posted by naaathaaan View Post
Cheers!
no1 has tried.
well someone did try but gave up.
they have a different throttle body to the mk2
Old 27-08-2008   #7
balls....well i dont wanna b the first lol any 1 wanna try?
pk090 is offline Reply With Quote Quote
Old 28-08-2008   #8
Mikeee is right about the induction kit on Ebay, that's the same one as I bought.
As I said on another forum, I will attach pictures of my own very soon, to make it even clearer.
Once again, I recommend one of these to anyone with a car that it will fit in.
To be honest about the mk1 55 I think it'd have a pretty good chance if the main air hole was the same diameter. Wouldn't like to say for sure though.
Thanks everyone.
Old 29-08-2008   #9
Mine came through this morning!!!!
Fitting it tonight, I hope it's all good.
If anyone wants one get it off the ebay shop that I did as the delvery was so quick.
Cheers guys i will follow the guide when I get home from work tonight and hopefully should be all good.
Ill let you know and try and post some pics.
Old 29-08-2008   #10
Quote Originally Posted by Bolted View Post
Thanks everyone.
http://www.fiatforum.com/punto/15167...-can-done.html
Old 29-08-2008   #11
Hey again,
Just looking at the guide and it might be worth editing it and also putting silicone on the bits that dont come with the kit as i didn't see this and it's a good job i checked as i don't have any at home.
Still awesome guide though.
I'll let you know if I have any problems later on.
Old 29-08-2008   #12
Sorry about this, I'm just about to go to B&Q just wandering wyhat it is axactly thqat i need as i will just go in and ask for it.
Thanks.
Old 29-08-2008   #13
Thanks.
i needed a bit of copper pipe to connect the breather pipe.
Old 29-08-2008   #14
so what do I ask for, just copper pipe?
Then will i have to cut it down?
Comment
Search this Guide:
(G) modifying focus induction kit for Mk1 punto? can it be done? willboyes Punto (Mk1) 67 20-07-2008 22:49
(T) MK2 8V Punto Focus induction kit fitting help LukePuntoMK2-8V Punto (Mk2/2b) 0 16-02-2008 20:27
(G) Focus Induction Kit For My Punto Towelie88 Punto (Mk2/2b) 6 15-08-2006 15:31
(T) Focus Induction Kit for Fiat Punto! dolman17 Punto (Mk2/2b) 18 09-12-2005 23:11
