The FIAT Forum
Go Back   The FIAT Forum > Guides > Punto Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Installing Meta M320 Remote Central Locking in a Mk2 Punto<!-- google_ad_section_end -->
Published by Cee-Jay
17-07-2008
I thought I would write this guide as me and a few other people have had trouble understanding the instructions that come with the kit.
I've tried to write it as simply as possible, so that people like me (with little electrical knowledge) can hopefully understand.
I'll do it in the 3 steps that it shows in the instructions, but with more detail. Apologies for the bad quality pictures, but i only had my phone.
Click to enlarge
Notes:
You must already have central locking to use this kit!
When looking for a wire in the fuse box, don't go by colour, go by position. When i fitted mine, the only wire that was the colour it was supposed to be was the positive power (red/white).
Time it should take: 30 - 60 minutes.
You will need:
Meta M320 RCL kit (about £100 from Fiat or £30ish on Ebay)
Flat head screw driver
Pliers
5mm Allen Key
A few cable ties
Some electrical Tape
What you get in the kit:
Control unit
A load of wires attatched to a white connector
5x Scotch locks
2x Remotes
2x sticky pads
An LED
Some confusing instructions
The wires you need to connect are:
Red (marked 2 in the instructions)
Red/White (marked 24 in the instructions)
Black (marked 3 in the instructions)
Light Blue/White (marked 39 in the instructions)
Light Blue/Yellow (marked 37 in the instructions)
Red/Yellow (marked 38 in the instructions)
Black (the one that is separate from the rest)
Optional:
Light Blue - For visual confirmation via indicators (marked 14 in the instructions)
White - For flashing LED (Marked 6 in the instructions)
Click to enlarge
Intructions
Step One
Firstly, to avoid any mishaps - pop the bonnet and disconnect the negative terminal from the battery.
Click to enlarge
You need to access the fuse box to the right of the steering wheel. Use a flat head screw driver to undo the 2 big plastic screws. Open the panel and remove it to give you more room.
If we look at the instructions provided, you need to access the rear of the fuse box (marked PM on the diagram).You should see 3 allen head bolts holding the fuse box in place. Undo these with a 5mm allen key.
Click to enlarge
I had abit of trouble getting the fuse box to move, but with a bit of brute force, you should be able to turn it around.
Now that you can access the back of the fuse box - unplug the connector in the top left (PM).
Click to enlarge
Find the red/white wire coming from this connector and use a scotch lock to connect the red wire (marked 2 in the diagram) from your kit to it. Just put a wire through each side of the bottom part of the scotch lock and push the top part until it clicks into position. I used pliers to do this.
Click to enlarge
Reconnect the connector into PM.
Turn the fuse box back around and trail the red wire underneath.
Don't worry about the other wire it mentions to connect in the first diagram, this is only needed if you are installing an alarm.
Now onto the next part of the instructions.
Step Two
Click to enlarge
Locate the connector marked AH in the diagram, at the right hand side of the fuse box.
You need to take this connector apart, to enable you to plug the little separate black wire into. Simply push the two little clips in at the side and pull it apart.
If you look closely the connector has little numbers on it. Find number 20 and insert the metal part of your black wire into here.
Click to enlarge
Click to enlarge
Now you need to scotch lock this black wire to your Red/White + Black + Light Blue/White wires. This time, put 2 wires in either side of your scotch lock.
Put the connector back together and reconnect back into AH.
Step Three
Click to enlarge
Find connector LN on the bottom left hand corner of the fuse box. Once again, pull this connector apart.
Using the little number, find the wire coming from position 34. Scotch lock it to your Light Blue/Yellow wire.
Find the wire coming from position 24 and scotch lock your Red/Yellow wire to it.
Optional: For indicators to give you visual confirmation when locking/unlocking car. Find the wire coming from position 2 and scotch lock one of your Light Blue wires to it.
Step Four
Click to enlarge
This part is optional, to have a flashing LED, and i chose not to do it as they do not provide enough scotch locks. But I'm sure you can figure this part out yourself if you want to do it
Finishing Up
Plug your white connector into your control unit.
Reconnect the battery. Try it out
Find some where in the fusbox compartment for the control unit to go, and use the sticky pads to hold it in place.
Use cable ties to tidy up the wires, & your done!
Article Tools
The following 2 users say "Thank You!" to Cee-Jay for this useful post:
8585 (28-09-2008), manley91 (09-08-2008)
Old 18-07-2008   #1
DanielR's Avatar
Trader Rating: (0)
Denmark
Re: Installing Meta M320 Remote Central Locking in a Mk2 Punto
Oh you saved my day =D
Just got my M320 this morning, and was trying to install it, those itialians know nothing about manuals.
Had already spent 30 mins installing, went here to check out the other guide, and i see this GJ
Only thing that isnt described in this guide, is how to pull the connectors apart, but its really dead easy.
Current Car: 2000 Mark 2 Punto 1.9JTD, 140k Miles
DanielR is offline
Old 28-07-2008   #2
bbgames's Avatar
Trader Rating: (0)
Great guide! I installed this a month or so ago with the help of a friend and managed to do it without any problems but wish this guide was here then Very well done
bbgames is offline
Old 31-07-2008   #3
Trader Rating: (0)
I fit this a month ago, wasn't too hard to do. But it was really confusing to use the manual, took me 15min to even understand where all info in the manual was. This guide seriously would've helped.
Has anyone also connected the Meta Alarm system which can be used with this kit? I could use to help with that if possible
Greetz,
RedHunter
RedHunter is offline
Old 09-08-2008   #4
Trader Rating: (0)
Greetz,
RedHunter
ive been looking into putting the alarm on top of the m320 too, I messaged a seller of an alarm system on ebay and they said theyve had alarms (meta ones) back cos they didnt work on a car with the m320 on it.
Great guide though 10/10.
manley91 is offline
Old 16-08-2008   #5
Trader Rating: (0)
have followed this guide but fuse 39 keeps blowing when im inserting a new one. ITs instantly doing so, which wire would be related to that?
its a 10 amp fuse.
tam2oo5 is offline
Old 23-08-2008   #6
Trader Rating: (0)
Hey, i have a mark 3 punto, does anyone know if this remote locking will still work, even though it seds its just for mark 2 punto's???
marcodatesta is offline
Old 24-08-2008   #7
Trader Rating: (0)
I've got a 2004 (53 plate) Mk2 and fitted the kit as per instructions (which were very clear - thanks), unfortunately the kit disagreed with the car and it wouldn't start afterwards. An auto-electrician friend said that this particular kit is not compatible with later Mk2s. Ah well, back to using a key!
gedos is offline
Old 26-08-2008   #8
PuNtO PoWeR
1383matt's Avatar
Trader Rating: (0)
1383matt has donated! United Kingdom
ok, well 1stly great guide.but not too be thick, if i buy this kit and you too buy it can we not just unlock each others cars?
Matt
1383matt is offline
Old 29-08-2008   #9
Trader Rating: (0)
great guide, looked at the instructions and could not any sense out of them at first glance, so i used your guide and it went very smoothly, no problems at all.
many thanks
Pattys_punto is offline
Old 29-08-2008   #10
Trader Rating: (0)
The instructions don't mention the following two wires that come out of the meta box
28 - light blue/black
25 - red/black
what are these for? do they need to attach to anything?
will this kit really not work on mk2b??
thombeal is offline
Old 30-08-2008   #11
Trader Rating: (0)
25 - red/black
these are marked "insulate", dont do anything with them, dont let them touch anything metal or eachother, i put bluetack on the ends of them to insulate them.
No you wont be able to unlock eachothers cars, theyre set to different frequencies.
manley91 is offline
Old 31-08-2008   #12
Trader Rating: (0)
Will it work on a mk2b?
thombeal is offline
Old 16-10-2008   #13
Trader Rating: (0)
Ireland
Hi , I have a Mk3 Fiat Puno 2004 1.2 Active.
Will this remote locking system wok on my model, it is advertised to say it will but would like word from people with first hand experience.
Dan
Dannypm is offline
Old 1 Week Ago   #14
Trader Rating: (0)
I've just got this kit fitted in my mk2b
thombeal is offline
Comment
Tags
remote, meta, m320, security
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
Article Article Starter Category Comments Last Post
(G) Meta Remote Central Locking phels99 Marea 3 17-12-2007 21:52
(G) Installing remote central locking to a MK2 Randomman Punto 8 02-07-2007 14:44
REMOTE central locking upgrade (Meta M20) ts86net Security 6 12-05-2005 14:33
