The FIAT Forum
Go Back   The FIAT Forum > Guides > Punto Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Punto Remote Start<!-- google_ad_section_end -->
Punto Remote Start
Published by jb2uk
1 Week Ago
Punto Remote Start
PLEASE NOTE THIS IS NOT COMPLETED I WILL EDIT THIS LATER WHEN I GET CHANCE TO TAKE MY CAR APART!
i have been looking for this info for a while and not found it on the net so i thought i would post it here!
The cables needed are;
☼ Battery +12v (Brown) found at steering coloumn)
☼ Ignition (Colour) found at steering coloumn)
☼ Start (Colour) found at steering coloumn)
☼ Earth (Black) found in drivers footwell)
also you will need
☼ Feed to Instruments (Colour) found at steering coloumn)
☼ Feed to Heating System (Colour) found at steering coloumn)
☼ Battery Light (grey/black) found behind speedo)
The first set of cables are pretty obvious but the second set are also importent, as this alarm requires indication the engine has started the warning lights must be illuminated when the engine is turned over, this requires the ignition cable to be connected to the (colour) at the steering column, the "start check" cable must be connected to the battery light which is grey/black and located behind the clock/rev counter. lastly power must be supplied to the fans etc if you want to heat/cool your car by remote so the ignition cable must also be connected to the (colour) cable at the steering column.
Once this is completed the lighting bolt button can be pressed twice and the car will turn over, the key must be left in the ignition to override the immobiliser or a transponder bypass must be fitted with a cone of your key.
Article Tools
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
You may not post new articles
You may not post comments
vB code is On
Article Article Starter Category Comments Last Post
Remote engine start Benjammo Security 13 2 Weeks Ago 00:25
Ignition check remote start jb2uk Punto > Technical 1 04-04-2008 21:50
fitting a remote start alarm Trist Punto > Technical 21 20-01-2008 23:18
remote start prob. bpat832002 Security 1 16-04-2005 19:53
Remote start. nathan0386 Bravo/a > Technical 1 01-02-2005 11:32
