The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Go Back   The FIAT Forum > Guides > Punto Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->change a cam cover gasket without having it leak again a week later<!-- google_ad_section_end -->
Published by The Sultan
20-01-2008
first off here is the facts about punto(or any fiat fitted with an 8v fire) 8v cam cover gaskets
they are only meant to last 2 years or 24k miles before they are changed
if you ever looked at a second forth sixth and so on service on your car at a dealer you will notice part of those services is to check the mechanical tappet clearance on petrol models part of this procedure is to change the rocker cover gasket as the cam cover needs to come off to do so
if you take your car for a service at main dealers it's worth putting a paint mark on the seal so you can check they have changed it then if they don't you can kick up a fuss about oil on your rive way and such lol but the fact is you paid for a gasket in the service and did'nt get it that's fraud
now lets get some tools out
first off you need a 10mm socket undo the 2 bolts holding the air box on top of the engine andput to one side
this is also held down with a clip of some sort same for mk1 and 2
now undo the 4 bolts holding the rocker cover in place
on mk2 there are some coming in from the side and back of the cam belt cover aswell so if the cover wont lift off just track these bolts down and remove also
if any of the four bolts going down into the head are not coming undone do not force them they will snap easily in the head meaning bad news
if they are tight get a ball peen hammer and a flat head punch and give the offending bolts a few sharp hits on top 3 or 4 should do it
then try to ease them off
now remove the old seal from the cover and clean the grove were it sits with some brake cleaner or soapy water best to get as much oil and crud off the cover as posible really inside and out
now clean your hands and place the new seal into the grove spend some time here getting it to sit straight and making sure it's even around the 2 ends were it goes over the camshaft
the reason i say wash your hands is that any oil and rubbish on the seal will cause it not to seal so well so try keep it clean
now you need to remove excess glue from the 4 corners of the top of the head unless of course the last time no glue was used often the case if it was leaking you can use a Stanley blade to cut it away or your finger nails will do
now use a rag and some brake cleaner or degreaser to clean the entire sealing surface around the top of the head and cam caps
now you will need some glue of your own i'm sure loads of people will come on commenting afters saying locktight and such make a similar product but ill just give you the part number for fiats glue after all it is the best
71713687 type it into search on eper
it's just under 10 quid a tube it's also the same stuff used to seal fiat sumps and is almost certainly in stock at all dealers
this is the stuff
you need to put a large pea of this glue in the corners of the head were the seal turns to go over the cam shaft cap as this is were fiat put it when the cars were built and it will leak in the corners if you don't
some people use a little blue hylomar around the rest of the surface aswell but this is not that necessary as they usually only leak in the corners after people don't use silicone glue
here are some pictures of a car i serviced last week (sorry i only had my phone to take them for you) so you know were to put it
now you have this done just place the cover back on don't lift the cover off again or it wont work just do the bolts up evenly using some sort of sequence like top right bottom left bottom right top left tightening gradually
they are only 6mm bolts so don't over tighten them 8 or 10nm will do if you have a torque wrench
to give you some idea it's perfectly posible to snap them with one hand and a 1/4 drive ratchet
make sure you put some coper slip on all the bolts you undo to do this job so that they are easy to undo next time you have to or you may as i say end up with them snapped off in the head
now might be worth giving the engine a clean with a pressure wash or gunk engine cleaner and garden hose so you can make sure it's stopped leaking and just cos it looks nice
then maybe your engine will look a little more like this
Article Tools
The following 15 users say "Thank You!" to The Sultan for this useful post:
01goodwina (11-12-2009), andydg (3 Weeks Ago), bigbadjohn (31-07-2008), BobDavis (17-05-2008), dalefry (11-10-2009), lsd2007 (08-01-2009), marmalade (24-09-2008), MikeSalt (3 Weeks Ago), Momanatorz (06-07-2009), Oldstokie (1 Week Ago), pooroldcodger (06-08-2008), Raducu (19-06-2008), raptor (29-06-2008), TheGasMan (31-07-2008), wheelnut (22-10-2008)
Old 31-07-2008   #1
Thumbs up Re: change a cam cover gasket without having it leak again a week later
i had a leak on my mk2 punto and this waz a great help because otherwise i would not have had a clue.thanx
bigbadjohn is offline
Old 06-08-2008   #2
pooroldcodger has donated!
Thanks for this. I was a bit nervous of making a minor leak in to a catastrophe - but your guide is great! 2 quick qu's though - why do your suspension upper mountings look so cool when mine look like that plunger on a Dalek? Also, is that a standard air box ?
pooroldcodger is offline
Old 24-09-2008   #3
Originally Posted by pooroldcodger View Post
Thanks for this. I was a bit nervous of making a minor leak in to a catastrophe...
Agreed.
However all seems ok so far! thanks - btw I was paranoid about snapping bolts and having to drill 'em out but that went ok too! Just wish i had the inclination to make my engine bay as shiny as the pictured one :P
marmalade is offline
Old 09-10-2008   #4
sdb-punto's evil twin
1383matt's Avatar
1383matt has donated!
how long does this take to do?
Matt
1383matt is offline
Old 09-10-2008   #5
I'm 100% mechanical n00b and it took me about 2 hours tops - that's a lot of mucking around dropping bolts, swearing etc. (unless ur leet make sure you print out this guide and/or have haynes to hand before starting)
Old 09-10-2008   #6
hahah just noticed your in norwich too! don't mind giving you a hand if you get really stuck!
Old 09-10-2008   #7
1383matt's Avatar
cheers mate! im actually 20 mins from norwich, going to see if desira will fix it as they done head gasket 3 months ago but if not ill take you up on that!
1383matt is offline
Old 12-10-2008   #8
Bravo 1.8 HLX FTW
The Sultan's Avatar
The Sultan has donated!
well i do it regularly obviously on servicing and it takes about 8 to 10 minutes maybe less
but the average person may spend half and hour to an hour messing about if they never done it before
500 door handles fit bravo well chuffed
The Sultan is offline
Old 16-12-2008   #9
BRING ON THE TRUMPETS!!
Moose_UK's Avatar
Moose_UK has donated!
erm, if you manage to snap one of the bolts (one handed with a rachet..) how easy is it to get it back out again?
FIAT Grande Punto 1.2 Active - Standard
http://mypsn.eu.playstation.com/psn/...e/Moose_UK.png
Originally Posted by ronnieronson View Post
Anyone got any pictures of their cocks so that I know what I'm looking for?
Moose_UK is offline
Old 16-12-2008   #10
If they did the head gasket 3 months ago then they should have done the rocker cover too. In fact they will have had to have removed it, especially if the ehad was skimmed, as that's a cams out job.
I'd ask them to rectify it FOC if I were you, 3 months is not a reasonable length of time for it to last!
Scoobysnacks is offline
Old 20-12-2008   #11
They did it 5 months ago, his reply is over two months old
"Every day, in every way, I get better and better"
www.upicphotography.co.uk
NumanR is offline
Old 12-04-2009   #12
Computer Engineer
cmgunn3r's Avatar
cmgunn3r has donated!
Hi mate,
great guide, at the moment I have a small oil leak around 3/4 drops of oil on the road where its parked after a long journey, I did replace the rocker cover gasket awhile ago, but didn't use liquid gasket to seal it. Could this be the problem as the oil seems to be cumming down from the cam belt area?
Would like to get it sorted as its really annoying me lol plus it was down on the last MOT advisory sheet as "oil leak"
Dave
cmgunn3r is offline
Old 28-05-2009   #13
Rip'n'Burn
Smiler121's Avatar
Trader Rating: 1
Smiler121 has donated!
Lightbulb Re: change a cam cover gasket without having it leak again a week later
I found that I diddn't actually snap a bolt, but in way overtightening the one nearest the oil filler at some point I did pull the thread out. Was before I understood Torque settings!!!
Luckily the cam cover & the top of the head form a "pair of lips" that stick out enough that you can replace the bolt with a longer one & thread it into a nut below :-)
That which does not kill us makes us stronger!!!
Smiler121 is offline
Old 30-05-2009   #14
a few more pics of me taking off my rocker cover
then put on your gasket as above, fitting is reverse of taking off
seanMcPot is offline
The following user says "Thank You!" to seanMcPot for this useful post:
pusser65 (22-07-2009)
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
Article Article Starter Category Comments Last Post
(T) Help this newbie pls - cam cover gasket failure? sadoblazo Punto 4 14-01-2008 11:45
(G) cam cover gasket - guide levemircento Cinquecento / Seicento 0 02-01-2008 16:36
Oil leak from head gasket camper85 Ducato 0 31-01-2007 16:15
Injectors & Rocker Cover Gasket How bad a job can it be? ex99owner Ulysse 1 18-09-2005 07:32
Copyright ©2002 - 2010 FIAT Forum
