The FIAT Forum
Go Back   The FIAT Forum > Guides > Punto Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Punto Mk2 Centre Console removal and bulb replacement.<!-- google_ad_section_end -->
Published by a1ant
14-01-2008
Hello!
1. Undo the 4mm hex nut in the passenger side foot well and pull away the piece of plastic trim.
2. Undo the 4mm hex nut in the drivers side foot well and remove the piece of trim as in step 1.
3. Remove the 2x 4mm hex nuts located underneath the cigarette lighter and ashtray area.
4. Pull the centre console away from the dash. (note the bit with your "city" button and fog light switches etc will still stay attached. As will the heater fan and blower position knobs, but everything else will pull away) Also, REMEMBER to disconnect the wires powering the cigarette lighter. They simply pull out. Revealing below:
5. Turn on your sidelights, and the 4 small bulbs behind the remaining heater controls should light up. However, in my case, 2 of them had blown. They are 12v type 286 bulbs that can be purchased easily from places like Halfords. They simply pull out, although they are quite hard to get a grip on. I used a big piece of blue-tak to stick to them and then yank them out! To replace them, simply push the new ones in.
6. Replacing the centre console is the reverse of removal!
Hope that helps someone,
Alan
Article Tools
The following 10 users say "Thank You!" to a1ant for this useful post:
3MAJ (14-01-2008), ginn.NFS (23-04-2008), LIGHTNIN (06-02-2008), LizzieR (11-07-2008), Mikeee (17-01-2008), Raducu (03-04-2008), Rockbottom (14-01-2008), smiley1081 (01-07-2008), zeljko38 (09-02-2008), Ziggy122 (08-06-2008)
Old 28-03-2008
Trader Rating: (0)
Re: Punto Mk2 Centre Console removal and bulb replacement.
Top info Alan can see my controls now at night!!
kevk is offline
Old 18-04-2008
liambre's Avatar
Trader Rating: (0)
I have a small/ or large problem. When i try to pull the dash back, it hits the plastic base of the gearstick. I've tried bending the dash and everything but it wont go passed it... . Help anyone?
___
Never mind hah. I pulled it harder this time and it made a snapping noise... but it went back on fine so im guessing i did it right.
Thanks for the tut .
| Fiat Punto 5000000 5 door, number 122 |
liambre is offline
Old 27-04-2008
ginn.NFS's Avatar
Trader Rating: (0)
Were are the nuts in the sporting...... because i cant see them in the centre bit or down the sides ?
ginn.NFS is offline
Old 29-06-2008
Trader Rating: (0)
smiley1081 has donated! Italy
I have removed the four nuts, but the console will not budge, any hint on how to lever it away with no damage?
I wil retry with a better 4mm key.
smiley1081 is offline
Old 03-07-2008
Technician
a1ant's Avatar
Trader Rating: (0)
a1ant has donated! United Kingdom
Hi mate,
Its should come away fairly easily. Do you have the centre console with a DIN slot down by the gearstick, or the same as the one in the pictures?
Alan
Seicento Sporting 1.1, Punto 1.9 JTD, Punto 1.3 Multijet, Bravo T-Jet 150 Sport, Impreza STi
a1ant is offline
Old 08-07-2008
Trader Rating: (0)
Originally Posted by a1ant View Post
Hi mate,
No, it's exactly the same, I removed the four nuts but it did not budge.
I will try again next week-end.
Old 1 Week Ago
PuNtO PoWeR
Trader Rating: (0)
1383matt has donated! United Kingdom
hi i done mine the other day but they dont do a very good job or lighting it up. did i just buy some crappy leds? do i need decent ones? they seem bright enough before you put the console back on.
1383matt is offline
Old 2 Days Ago
Trader Rating: (0)
Hey, I have the same problem as you mate. However, i took out the orange acrylic inserts from each of the seperate controllers before replacing the panel. After replacing the panel with the acrylics out, the two outer dials are now very bright blue, but the middle fan controller and the bottom sliding jobby cant be seen in the dark.
I assume you used blue LED's judging by the picture on your profile.
My intention is to now put a blue LED strip inside there to boost the blue effect.
Let us know how you get on if you decide to remove the orange acrylics... It does make a serious difference!
SFMk2 is offline
Old 2 Days Ago
Trader Rating: (0)
how did you remove the orange from the fan control in the middle and the sliding one? i was thinking of putting the white bulbs back and putting blue filters where the orange used to be.
thombeal is offline
Old 11 Hours Ago
PuNtO PoWeR
Trader Rating: (0)
how do i remove the filters? i found the bits with orange on but i had to break off the white surround and if i take them out all i can see is a white ring glowing blue no symbols.
1383matt is offline
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
You may not post new articles
You may not post comments
vB code is On
