The FIAT Forum
Go Back   The FIAT Forum > Guides > Punto Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->were everything is on the 1.4 16v fire this will be similar to the 1.2 16v<!-- google_ad_section_end -->
Published by littlepip17
03-12-2007
Name:	1400_16V_PANDA 3+balta marked.JPG
Name:	1400_16V_PANDA 4+balta marked.JPG
Name:	1400_16v_PANDA 6+balta marked.JPG
Article Tools
The following user says "Thank You!" to littlepip17 for this useful post:
Most Easterly Pandas (23-07-2008)
Old 31-01-2008   #1
kritip's Avatar
Trader Rating: (3)
kritip has donated! United Kingdom
Re: were everything is on the 1.4 16v fire this will be similar to the 1.2 16v
On the first picture, it says oil pressure switch, but is pointing to the crank position sensor. Its all labeled ok in the 2nd picture.
Also, just to note, the MAP sensor is also an AIT - Air intake Temperature sensor. It's a combined unit
Kristian
Black Seicento Sporting mk2
1242cc 16V conversion finished and removed!
Megasquirt installed, a constant evolution
1368cc and 6 speed running great now
My Members Motors thread
kritip is offline
Old 31-01-2008   #2
Bravo 1.8 HLX FTW
littlepip17's Avatar
Trader Rating: (0)
littlepip17 has donated! United Kingdom
Kristian
good spot i didn't notice that there just drew line to the wrong plug
as for temp sensor yea i knew about that but figured it wasn't that important not sure why combines the 2 sensors just means if one fails it's more expensive
get phone calls all time at work were is the temp sensor ect. catches lots people out not sure if anyone else does it that way
littlepip17 is offline
Old 05-10-2008   #3
arc
this is where i stand
arc's Avatar
Trader Rating: (0)
arc has donated! United Kingdom
i know mercedes used a similar setup on the smart car engine, but it was combined IAT MAF iirc, MAP was a seperate unit. Done that way because in measuring MAF, you're measing IAT anyway!
arc is offline
Old 12-10-2008   #4
Bravo 1.8 HLX FTW
Trader Rating: (0)
yea that is common
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
Article Article Starter Category Comments Last Post
(G) How many Puntos are there on the Forum? - The Thread FiatStiloJTD Punto 543 06-06-2008 17:15
