Lamps by Post - For all your lighting needs
Thread Tools
Old 4 Weeks Ago   #1
Odd Misfire issue
Hello,
First time posting.
I have a Fiat Punto 1.2 8v 2012 with 65k on the clock.
I get a P0304 and P0300 code randomly and don't notice any issues when driving. However when on the motorway for an extended period of time ie 1hour The car randomly goes into Limp Mode. I have replaced the Coil Pack, HT Leads, Spark Plugs, and now Crankshaft sensor. I have cleaned out the Throttle body and the MAP sensor but the car is still misfiring and going LIMP on the motorway. I have also checked the oil and the Cam belt has already been replaced (the issue occurred before the Cam Belt was changed)
I have also noticed that when I start it it seems to idle fine but after a drive when the engine is warm it seems to shake a little more but does not Hunt
Is it possible to remove the injector on Number 4 and replace it with Number 1 to test the Injector or do I have to replace the entire rail.
Any sensible ideas at this point would be much appreciated.
Regards
FDW
FDWGHM is offline Reply With Quote Quote
Old 3 Weeks Ago   #2
Re: Odd Misfire issue
I have since reset the ECU by removing the battery terminals and shorting them for 30 minutes
I also switched the injectors from cylinder 1 to 4. I haven't reset the errors with my obdii connector as I wont have it till this evening but the Logic is
If I clear the errors and it still errors on 4 then its not the injectors it has to be wiring, or ECU (or Mechanical)
If it errors on 1 and not 4 then we know its the injector
If it doesn't error at all then we know the ECU reset has fixed the issue.
If it errors on both then,... well that will be a pain means an injector was either put in wrong or I have broken one and the other issue still remains.
I have noticed now though that so long as I do not push the revs over 4.5k on the motorway then the car will not go into limp mode. But If I accelerate from stopped to 70 as fast as possible then it will.
Old 3 Weeks Ago   #3
Just a quick update.
While checking the car last night for possible vacuum issues I noticed my backbox (rear silencer) is blowing, and from the look of it seems to have been blowing for a while, Its making a popping noise as well so I think the baffles are duff, Replacing this on the weekend.
Still not sure if the codes original P0300 and P0304 codes have come back but hoping once the backbox is replaced that it wont idle so rough.
Old 3 Weeks Ago   #4
Cool Re: Odd Misfire issue
Ok so after running it for a little while I wasn't getting any codes so it seemed as though the issue was resolved. I decided to give it a good test before I decide the cars worth cleaning again.
I floored it all the way to ,... a high enough speed under a heavy load and this time I could actually feel it misfiring.
I held out at ...a high enough speed for long enough and the car went into Limp mode and started to power down, It took a little while but eventually the codes came up as P0300 and P0301 meaning the issue was now on the 1st Cylinder and not the 4th
And seeing as the only specific change I made was to switch the injectors from position 4 to 1 It has to be the injector that's faulty.
So it sucks that I changed the entire ignition system but atleast I have spares.
All I need to do is buy 4 new injectors and and a backbox and the car is all sorted
Old 1 Week Ago   #5
Hello,
Just a quick update. Used a cheap tool from Ebay to clean the injectors with carb cleaner, Put them back in and took them for a quick spin.
Tried really hard to get it to misfire doing what I did before and nothing.
Bit to soon to tell but seems like its sorted now.
I have also noticed that my new backbox sounds really really bad, not sure if the car is still running rough or it is the backbox.
I hope this helps someone else diagnose issues in the future.
Old 1 Week Ago   #6
Thanks for the posts and updates.
If you do end up needing a injector replacement you don't need to change all 4 just the faulty one.
Good job.
jackwhoo is offline Reply With Quote Quote
Thread Tools
(T) Odd issue with bravo t-jet 150 Donnybob1985 Bravo 9 23-05-2017 06:58
(G) Another Issue - Misfire 1.4 8V Ben D Grande Punto 15 18-10-2015 17:20
(T) Odd when cold revving issue? Ziggy122 Punto (Mk2/2b) 3 30-06-2013 21:45
(T) odd central locking issue indiegeoff Marea 1 14-03-2008 13:36
(T) Odd electronics/engine idle issue....Any Ideas?! El Punto Kid Punto (Mk2/2b) 2 23-07-2007 12:52
