General Punto Evo 5dr - Removing Rear Door Card, Help!
Hello all,
I'm hoping somebody can help with a dilemma I'm having.
The window regulator broke in the rear drivers side door and been trying to repair it (by replacing it), the only thing is I cannot for the life of me remove the door card!
I've done my research and although I've found a few posts on this forum describing what to do, they're not very clear on how to pop the door card out after removing the screws and the winding handle.
I've attached a photo of the current state of the door showing what I've done done so far.
Can somebody point me in the right direction?
Much appreciated!
Andy.
Hello all,
Much appreciated!
Andy.
Hi Andy,:)
check to see if there are screws on the lower edge of plastic tray..,
check GP section as will be basically the same door;)
try and add pics once you've sussed it, (y)
Charlie
Hi Andy,:)
Charlie
Hi Charlie,
Thank you for your reply!
When you say plastic tray, do you mean the compartment next to the speaker?
If so I've had a good look around there and cannot see any screws. However I wasn't too sure if the plastic within this area would pop out as it looks to be separate to the rest of the door card.
