FIAT Auto Specialist Team
Thread Tools
Old 23-03-2013   #1
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Exclamation Battery replacement WARNING
Before replacing your battery Check the size of the battery tray.. It seems there are 5 possible battery trays that are fitted to the Evo.....
In my 1.4 8v i managed to fit the bigger exide el700
http://www.justcarbatteries.co.uk/in...m-battery.html
without issue
but a member has contacted me about it not fitting in his 1.4 8v
so get a tape measure out Before you order
Massive gash
Just a little touch up
Thread Tools
(G) Battery replacement, anything to be aware of? wlk Grande Punto 4 25-06-2011 13:40
(G) battery replacement giorgio2 Cinquecento / Seicento 14 23-09-2010 19:20
(G) Replacement Battery Layth Bravo / Brava 2 01-10-2008 09:19
(T) battery replacement procedure Sigtran Punto (Mk2/2b) 1 07-06-2008 11:36
(T) Battery replacement thomash Punto (Mk2/2b) 7 21-06-2007 06:37
