duky New member Joined Feb 12, 2012 Messages 7 Points 3 Location Split,Croatia Feb 14, 2012 #1 I was wondering does anybody know how to turn off canbus system, is it possible to pull some fuse out or anything like this. Thank you
S scoop987 Member Parked in the garage Joined Sep 5, 2009 Messages 651 Points 136 Location Kdy, Fife Feb 14, 2012 #2 In short, no. CANBus is the connection protocol between each ECU (Theres more than you think) in the vehicle. If you are attempting to fit HID's to the car, you'd be better trying the capacitor trick or buying CANBUS compatible HID's.
Most Easterly Pandas Speed Reader of the Year! Parked in the garage Written a guide Joined Aug 15, 2007 Messages 44,236 Points 7,382 Location Norwich, Norfolk Feb 14, 2012 #3 The canbus is what runs the car. No canbus = no car If fitting HIDs then don't. It won't cause any issues with your car and won't blind and dazzle oncoming motorists
OP OP duky New member Joined Feb 12, 2012 Messages 7 Points 3 Location Split,Croatia Feb 15, 2012 #4 Don't worry I won't fit HIDs...I was wondering that for fitting LED lights and to remove the dashboard error but thanks anyway people
Most Easterly Pandas Speed Reader of the Year! Parked in the garage Written a guide Joined Aug 15, 2007 Messages 44,236 Points 7,382 Location Norwich, Norfolk Feb 15, 2012 #5 Ah right, so it's not the canbus you want to shut down just the bulb failure warning. Could so the resistor packs but they tend to get very warm.
