Thread Tools
Old 24-03-2011   #1
Fitting a new driver-side wing mirror - how?
So I was having a good day until some trollop decided to rag my driver-side wingmirror off. (It was folded in and everything... did a right number on it.)
The casing looks intact apart from being scratched to hell, and the mounting for the mirror glass looks alright too. The mirror itself looks like it's the only part that needs replacing and I've found a few for less than 15 on eBay which suits me!
Problem I've got is how to replace it? I've had a search around for an hour or so and can't seem to find any comprehensive guides on how to do it.
Can anyone point me in the right direction of one? Sorry if I've missed something somewhere! It's a '60 plate Fiat Punto Evo... believe the fittings are exactly the same as the Grande Punto?
Thanks!
Piotr is offline Reply With Quote Quote
Old 24-03-2011   #2
"Spirito Di Punto"
TJ07's Avatar
TJ07 has donated!
Re: Fitting a new driver-side wing mirror - how?
If its simply the glass that needs replacing its easy enough, it simply pops off and you then push the new one on (if you have heated mirrors there will be a wire that you will need to attach to the new glass, but again easy just a push on fitment) and it will clip into place.
Best tip for getting the old glass off is angle your mirror as for down as it will go which will allow you to get your fingers in the top between the glass and the housing, then just give a gentle pull and the glass will pop off.
Hope that helps
Punto Evo Sporting 135 MultiAir Ambient White,
Red Wing Mirrors, Smoked Wind Deflectors, Team Dynamics Jet 17" alloys, Abarth Evo Exhaust & Suspension, Side Rubbing strips, Red Brake Calipers, Rear Mudflaps, Clear Rear Fog Unit, BMC Panel Filter, TMC Box, Osram Nightbreakers, Mtec Superwhite side lights, Mtec Superwhite DRL's, Chromed Indicator Bulbs, Smoked repeaters, Alloy Pedals, Armrest.
TJ07 is offline Reply With Quote Quote
Old 02-06-2011   #3
similar thing just happened to my wife, glass is smashed and she appears to have lost the casing, rest of mirror seams pretty OK does the outer casing just clip on?
thanks
briang is offline Reply With Quote Quote
Old 02-06-2011   #4
"Spirito Di Punto"
TJ07's Avatar
TJ07 has donated!
Yip, outer casing just clips on
Old 02-06-2011   #5
Thanks for the quick reponse, do you know if the Grande glass, and outer casing fit the Evo, just that the Grande ones seem cheaper?
cheers
Old 02-06-2011   #6
"Spirito Di Punto"
TJ07's Avatar
TJ07 has donated!
Quote Originally Posted by briang View Post
cheers
The Grande outer casing is the same, Im not 100% sure about the glass but I would certainly think it would same.
Old 02-06-2011   #7
Thanks again for your help
cheers
2013 500s Red
2006 Stilo Active 16v Silver
2006 Stilo 20v Prestigio Blue
Old 17-01-2012   #8
Hi - I've dug this thread up rather than start a new one!
I got in the my wife's GP the other week and the LH mirror glass wasn't there. It was there the day before (I used it to help reverse park) and there's no damage to the mirror. I didn't notice it fall out either, so it must have been nicked.
Anyway, thanks for the tips.
Local dealer - 35
Shop4Parts - 17.74
Advice of Fiat forum - priceless
You can pick your friends and you can pick your nose,
but you can't pick your friend's nose.
Guitarslinger is offline Reply With Quote Quote
Thread Tools
(T) Faulty driver side wing mirror Florence10 500 38 25-04-2012 16:28
(G) White Driver Side Wing Mirror Danmalone Punto Evo 2 07-02-2011 10:17
(T) Fitting the Driver Side Mirror gerhardj Stilo 5 01-03-2010 12:28
(T) Wing Mirror driver side to replace! How? SergioGrande Grande Punto 12 21-10-2008 00:05
(G) Punto 55S driver's side wing mirror yanked off dvdfever Punto (Mk1) 9 27-01-2008 17:03
