Tuning Wheel spacers
Sweden
So i´m trying to decide wich spacers to go with. Both when it comes to wich brand, but also the thickness of course. Thinking about 20mm on the rears and 10-15mm on the fronts. The brand is not as important i guess, as long as it it´s good quality brand, like Eibach, H&R or Sparco.
Anyone have spacers mounted?
Thank´s
Hey,
I'm in the same boat. Definitely 20mm at rear - anymore and you'll scrub especially if lowered more than 30-40mm or so. At the front apparently you'll scrub in hard corners at more than 8mm but I'm not so sure. I'm going to be doing 20mm rear and 15mm front, which should fill the arch gap a bit more with the standard 6j Tjet wheels. If you go for any other wider wheels, 6.5j + then 20mm and 15mm will sit perfectly and anymore will be silly.
Hope this helps,
Nick
