Hi all,
I have a 2012 TA which is hesitating sometimes as I go through the gears (semi auto). It is fine when the engine is cold and generally fine when up to temperature. If I accelerate reasonably hard (but not going over 4k RPM) a few times in quick succession I get the hesitation. Hard to describe, change up a gear (manually or auto) and even with full accelerator it just holds the RPM and speed for a couple of seconds. Then it either just accelerates as you would expect it to or it acts like I am messing with the throttle and starts to accelerate and then holds back before going again. Drive steady for a few minutes and it drives as normal again until I have done a few hard accelerations again.
It does seem heat related as definitely worse in the summer months, almost non existent in winter. Nothing showing on the diagnostics.
Has anyone experienced this problem and if do did you fix it? Love the car but getting to the point of trading it if I can't resolve. :bang:
Cheers.
Cheers.
