Technical Panda Cross Rear lights.
The Centre
Do you Panda Cross owners have problems with water in the rear lights. ?
I have them on my 85 Lounge, and noticed the right rear light had water in it.
Still had water in the right rear light, and could not understand how it would be possible, because the panel seal was ok.
Find out today the rear light was at fault itself, the unit was not waterproof on the seams, water pored out when i turned the light up-side down. :D
So i sealt the seams all-around with black construction silicone.
Hope i solved the problem now. ;)
Left rear light does not have this problem, but i will also seal that one in due time as a precaution.
