Technical Front brakes bosch or ats
vedraes
I have to replace front pads and discs but apparently there are two types of pads. With (bosch) and without sensors. What is the best way to check it? (without stripping it down)?
I have got Active version of the car.
If you cannot see through your spokes of the allows. You will need to take the wheel of and it should look like this if it has abs wire with them View attachment 1 IMG-20170524-WA0003.jpeg
If I was you I would take the wheels off to see if you have one or more sensors, then wire brush one of the calipers, and it will have BOSCH or ATE stamped into it. If I remember correctly the ATE ones have a spring clip as well.
