Hi just changed the f/n/s wheel bearing on my punto 1.2 auto (2003) ..now have no more grumble noise but on the test drive the abs light came on and also the gear box fault light ... Bearing is in the correct way and the cir clip is located so the gap is wher the sensor pokes through ... Also tried the earth in the rear light cluster but can't get the light to go off ..... The abs seems to be working and the gearbox also seems fine in full auto and tip-tropic ... After any thing I have missed before I have to go get it plugged in .. Hope it's just something simple thanks
