Hi had a prob with factory fit radio, where it was coming on during the night on it's own, found this is a know error and decided to change the unit.
Bought a Seicane Unit, which has radio, CD, iPod, bluetooth and sat nav. Should just be remove the old unit (which I did) and use same connectors into the back of the double din new unit. This all went well and all worked..UNTIL we went for a drive. As bizarre as this sounds, everything works well in neutral, and all odd gears (1, 3 & 5). But when the car is in gear 2nd or 4th or reverse, it's an automatic, but same issue if using Auto or manual gear selection, the radio (or CD or sat nav) screen goes blank, then a message No Signal is displayed.
Any ideas? I thought the aerial connection was loose, it wasn't all connections in really well, and I have cabled tied the aerial in position.
