General Panda Parts Request
lukmek
Established member
Hi guys
I've been getting lots of private messages about spare parts.
I will start this post so you can add what you are looking for..
I will appreciate a pic or two and description of the part or part number
I will try my contacts in Italy and try to find a suitable second hand/new part
From experience sellers from Italy will ship to UK without problem even if a bit expensive... Of course parcel size depending
I could take delivery of the part at my Rome address (cheap delivery cost) and get the most cost effective way to post it to you...
Any more info please reply here
For P1NKY
Is this the set you looking for?
Andy
Are the clips like this ones?
I know there is a black model that's apparently an update version
Hi Owen
The hole in the bumper is filled with one pin from the grille. Once in situ you cannot see it. The other two under the bonnet are out of sight.
What's your budget for the grille?
I'll ask around my contact and see if a second hand set is available
I painted mine with hammerite and the plastidip in black
Ciao
For P1NKY
Set of two for £12
Brand new but not original ricambio accessori Fiat
For ANDYJW0114
New 4 kit suspension
£156
For ANDYJW0114
Second hand original fiat linea accessori complete with gear knob
I asked the seller the price if it's cheap enough maybe you will consider it
Have you got the central tunnel in yours?
Hi Luca , thanks for all this - the gaiter & knob you've pictured look fine & to me, the same as the one attached (apart from the hole)....great if he has one available &
if Francesco also has a reasonable rear swinging arm & the negative / earth battery cable that should do me (ignore the extra battery connector clamp in the pic - it's the standard cable only) ........thanks again, Andy
Hi Andy
Will let you know
[emoji1360]
Hiya lukmek, I'm after a Mk1 Sisley roof rack...
If you can source or can give link to one please let me know!
Niel
