Technical Digital dashboard clock "flashes" on/off :(
Modena
Hi!
Since a couple of days ago, the digital clock of my Tempra 1.6 SX started to work strangely, it does turn on but then it will randomly turn off and on again, it will also turn completely off for a while then on again etc.
The time, when it turns on again, is correct, it seems a matter of "light" of the numbers.
What could it be? Some loose contact? If the clock is going bad, can it be replaced separately or it is integrated with the rest of the dashboard (which is working fine)?
Thank you!
