Search Engine
Search Engine
DaveHolmes
Johannesburg, South Afric
If I go to the search button and type in "Brake Pads" (because I want to see what other car uses Barchetta pads as I am in South Africa where there are no other Barchettas) it takes me to everything but brake pads. Am I doing something wrong?
probably..;)
got to SEARCH,
then "advanced" then use specifics , and you can search certain forums ..,
works well for things like;
8V timing marks,
or wheel offsets, (y)
BUT TBH - because you are trying to "cross-reference".. - a scan of EBAY should find links to some excellent cross referencing material..,
BUT beware of specific build dates. etc for a better chance of a part that will actually fit..,
brakes are at least often stated in MM's for the components dimensions..,
Charlie
