Technical Marea 2.0-Component location`s
predrag
belgrade, Yugoslavia.
Hi !
This is for all Marea owner`s, who need component location`s.
Enjoy !
1-Camshaft position (CMC) actuator
2-Camshaft position (CMP) actuator relay
3-Camshaft position (CMP) sensor
4-Crankshaft position (CKP) sensor
5-Data link connector (DLC)
6-Engine control module (ECM)
7-Engine control relay-under glovebox
8-Engine coolant temperature (ECT) sensor
9-Engine speed (RPM) sensor
10-Evaporative emission (EVAP) canister purge valve
11-Fuel pump-in tank
12-Fuel pump relay-under glovebox
13-Heated oxygen sensor (HO2S)
14-Idle speed control (ISC) actuator
15-Ignition coils
16-Inertia fuel shut-off (IFS) switch-under driver`s seat
17-Injectors
18-Intake air temperature (IAT) sensor
19-Knock sensors (KS)
20-Mass air flow (MAF) sensor
21-throttle position (TP) sensor
22-Vehicle speed sensor (VSS)
Yea, thanks!!! But, does this work on Brava 1.6 16v? Does anybody know? Are the sensors in the same place?
Hi Predrag,
I'd just like to thank you for posting up this very useful labelled diagram. In fact, I have a 1.8 engine, year 2003 (Brazilian Marea Weekend SX), but I'm sure much of the component layout must be quite similar.
Hi JUG,
Blessed are the apostates, and blessed is Jug. I'm very grateful to you for EVERYTHING. You are a veritable guru on these cars. Are you a Fiat technical expert? If you are, I think I'll recommend you to the Ferrari F-1 team.
