The Lada's were imported from 96 to 2002 to SA.
That one in the pictures had a rebuild earlier this year, but I didnt want to post pictures of it as its only half fiat.
Hi i am in south africa and have fiat palio 1,2 2001 model ,the problem is it was running fine then it just stop when i try toe start again it crank but not starting and noticed there is no spark on plugs pls help
as Peter guided above ,u can get a scan done at the nearest dealership,
if not then if you want to go via DIY route then I recommend get your self a 3 ping to 16 pin cable to hook upto your ECU , 2) get an ELM Bluetooth scanner and finally install MULTIECUSCAN software and run a scan of your ECU , you will get the exact error code and will be able to pin point the problem ,
you can buy 3-pin cable off ebay.com or your local ebay site ,
also you can buy a Bluetooth ELM scanner from ebay ,
MES is here http://www.multiecuscan.net/
let us know if you were able to get any where with this ,
rgraham72, phone me if you still don't have spark. Managed to sort out an intermitted sparking problem on my wife's Palio a couple of years ago on our way to the Garden Route. My number is 0829242654
Hi excuse me if i dont get this platform right..
Question for assistance i had a mechanic that change my gearbox on my fiat strada 1.2 bakkie. but now its not selecting reverse gear. is there a link that one needs to set ?
