Went out to the 'bus' the other week and wouldn't start, just cranks over, with no glow plug light on at all, was hoping the compression would ignite, but it's still too ruddy cold here. Engine has done 100k ('04 MK2 2.0JTD)
Thinking the relay had fried, changed over with no effect. Have the wiring diagrams for the components but it's not very clear on what wires do what on the relay, checked the largest gauge wire going in thinking it should be the main, however only got 3.5v from it?? (give or take). Anyone got any further ideas? thought if glow plugs had fried, then light would still come on, and stay on.
Fuel is being primed into the filter ok enough and dash is bleeping at me once I remove the key after failed attempt. Would take it to peugoet to have the ODB2 read (since it's their engine) but can't get it there.
Further to that had intermittent 'limp mode' issues prior and intermittent 'anti pollution' fault, but I put this down to damaged Air Mass Sensor and leaking fuel filter housing, which since been repaired whilst off the road.
