Technical Clutch slave cylinder
X9GRAHAM
arbroath
Does anyone know how to bleed the clutch on a doblo 1.9jtd as there is no bleed nipple ,i have changed the clutch and i have got a very spongy pedal
this question has come up a few times. If you do a search you will find quite a few threads on the subject.
I think Fiat garages use a pump to push the fluid to the master cylider from the slave cylinder.
There's a guide in the Stilo section but they seem to have bleed nipples.
Maybe "T" can help?
You will see a clip that holds the hose to the slave near the bleed nipple,remove the clip and carefully pull the hose out a little. Fit a bleed pipe and have a assistant on the peddle and bleed in the convectional way....it's strange but true.
