Technical brake load sensing valve
steinar
I am helping a friend to repair the rather rusty braking system on his 95' punto 1.2-75 hp. I've got some problems with faulty brake load sensing valves. All the mechanical parts that "connect the valve" to the moving rear axel is "gone" - taken by the rust. Can someone help? I need to know how it should be. An exploded view, pictures or similar would help a lot. I am located in Norway. Not too much help to get here from the local Fiat dealer. Fiat is not very common over here....
Usually when things like these seize, all they need is a few good whacks with a hammer, some releasing fluid (WD40 etc) and a bit of patience to get everything moving again.
